sorted
I've not heard of them ever being reset.Do these airbag warning lights show up as a fault on an OBD port reader?
Has anyone checked with an ODB reader.?
I just wanted to determine if the fault had been picked up on an OBD port scanner.I've not heard of them ever being reset.
Mine was checked at the garage with a professional reader and I was told its a ECU fault and quoted £250 for a replacement
Excellent - The first time I have of one being reset --- Be sure to buy a lottery ticket on Saturdayi was more than a bit pissed I have to say.
rushed in and got the laptop plugged in to OBD, fired up Multiecuscan and I cleared the fault.
was holding my breath as i did it.
switched on to check today and so far all is well.
Can you fix ours too please?
(new motorhome with less than100 miles on it)
That is a common code that crashdata tell you the unit is trash. It would be interesting to hear if the strip down resolves it.An example post From the fiat forum
Erased the codes.
Airbag lamp still lighting.
I have done a scanning with my tool and it says:
B0102
Connec. to ECU container ground.
This error code indicates a fault in the connection between the metal case of the Air Bag Controller and the Vehicle Ground. I suggest you remove the 3 (?) nuts, clean the contact areas and reassemble. Maybe the position under the floor makes it vulnerable to water from snowy Swedish Boots ?
There is another ground connection via a wire from the Air Bag Controller M060 to the Ground Point C050 nearby. I suggest you check this out too (See pictures).
I have no personal knowledge of this problem
I think we worry too much. We never used to have airbags?it’s dangerous as your airbags will not inflate in an accident.
I had the fault for 6 months when it first happened.I think we worry too much. We never used to have airbags?
If I had a vehicle eith this fault and had to replace the module it would only be fitted for an mot then removed.
Better make sure your seat belt is not fitted loosely. The tensioners probably won't activate if you prang it.I had the fault for 6 months when it first happened.
Fiat advice was it's OK to drive as the bags are deactivated. Just no airbags deploy in an accident. So drove around as normal until I could get it fixed properly.
It's not dangerous to drive with them deactivated, it will just be of no help if you prang it.
Don't need to now I fixed it. The problem was that they all struggled to fix it.Better make sure your seat belt is not fitted loosely. The tensioners probably won't activate if you prang it.
Will do, i am updating my spreadsheet as new info becomes available.You can add me to that!
New 2022 (2021 model) with failed Airbag ECU.
Failed at the dealers one week before I was due to collect it!
Currently awaiting new ECU from Fiat (to be replaced under warranty).
I suppose if you had a bump at the front ,if the ecu was working the airbags would deploy and that would be a really expensive repair. Does anyone know at what impact do airbags deploy at?I had the fault for 6 months when it first happened.
dont know the speed or force,I suppose if you had a bump at the front ,if the ecu was working the airbags would deploy and that would be a really expensive repair. Does anyone know at what impact do airbags deploy at?
