Air suspension (1 Viewer)
Dec 28, 2011
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
We have sold our Autotrail Comanche and are now waiting for our new Etrusco, on a Ford chassis, to be delivered. Seven months and counting so far. I am thinking of fitting air suspension and my question is, has anyone fitted it to a new Trannie chassis yet, and if so, which one and was it worth it? I am also going to uprate the weight from 3.5t to whatever the maximum is.
I am sure someone on here will have done it but can't find it in the threads.
Oct 15, 2011
4,190
11,382
Not Glasgow
Carthago chic eline
Since 2011
Not on a Tranny but a Fiat Ducato, got full VB air fitted at A&E Leisure a couple of weeks ago. Smooths out our atrocious roads pretty good, plus it can be used to level the van. Their prices are very competitive.
knokinonabit
Dec 28, 2011
2,426
2,769
Don't think I've ever seen anyone mention full air on a Trannie on the Forum.
We have Goldscmitt full air on our Ducato based Hymer. Wouldn't have a van without full air now.
When you say full air, is that replacing springs/torsion bars on the rear axle, or air on front and rear axles ?
Sep 17, 2017
5,520
10,317
Birmingham, UK
A-Class
I've got VB full air on a Ducato chassis'd a-class. Going around the roads of North Norfolk last couple of weeks made me appreciate how much of a difference it makes. I still getting rattle and shudder on the bigger imperfections, but it's mostly noise rather than feel. The ride is pretty smooth.
In the week, I got a lift from a family member to Kings Lynn in their Skoda Karoq, a mid size SUV that's not particularly sporty. Although it was quieter, it was way more jiggly and rough than in my van.
knokinonabit
Dec 28, 2011
2,426
2,769
Same question to you as to Lenny HB. Is your definition of full air to replace springs/torsion bars on the rear, or all axles with full air ?
The A& E Leisure site quotes VB Suspension as Full Air Rear and Full Air Front, not Complete Full Air.
5,520
10,317
Birmingham, UK
A-Class
I no longer have leaf springs at the rear or conventional sprung struts at the front. It's all air bags. VB 4C system. £8k!
Lenny HB
53,648
150,797
On the coast in West Sussex
Hymer B678 DL
Yep, Front struts replaced with airbags, on the rear torsion bars replaced with lightweight ones they are needed to locate the swinging arm & airbags fitter.
Normally referred to as Full 4C air (4 corners).
knokinonabit
Dec 28, 2011
2,426
2,769
Thank you for the info. I’ll be looking into getting our new MH done when it eventually arrives
knokinonabit
Dec 28, 2011
2,426
2,769
Yep we will to when the new van arrives, unfortunately I can't transfer the Goldschmitt as Carthago don't approve it, probably because it's a Hymer company.
Our new MH is an Etrusco, also a Hymer company, so I will have to see if it can be done.
Apr 21, 2008
827
2,066
bedford
I have vb air on my Frankia with ep levelling
Very good but a pain in the arce waiting for air to go before levelling will start.
My Volvo air is almost instant
Oct 29, 2008
5,078
5,990
West Yorkshire
PVC
since 2008
Have you ever had the software updated. When my full air and leveling was first fitted it took time to wait for yhe suspension to drop before leveling started. After the update it was a lot better. Mick at SAP knows everything a person can know about the air and leveling.
Apr 21, 2008
827
2,066
bedford
No haven’t had an update,but when back from holidays will get it looked at, thanks for the advice
Aug 12, 2021
639
1,417
Nantwitch Cheshire
A Class N+B Flair
25years
I’ve had goldschmitt air on the rear 20+ years and on my hymer before for 7 cant imagine been without it heavy duty front springs and a large anti roll bar handles like a Quattro oh and wheel spacers+a large fuel tank135 Ltires ,they don’t do front air for the old model such a shame.
knokinonabit
Dec 28, 2011
2,426
2,769
I've sent off enquiries to see if I could have full (all four corners) air suspension fitted.
SAP say only on the rear with VB, and I'm waiting for a reply re Goldschmitt.
I'll update when I have an answer.
knokinonabit
Dec 28, 2011
2,426
2,769
Time for an update.
I've had a reply from RV Installations re full air suspension for a Transit base, which is as follows :
Goldschmitt only offer rear semi air for this vehicle. VB offer a 2 channel full air system for the rear axle, but currently neither company are producing a front strut to allow a 4 channel system.
So it would appear at the moment that it's a no to full air for the Transit base.
Unless anyone knows different of course.
OldAgeTravellers
1,212
1,395
Telford, UK
Since 1970
bigtree , Mike at SAP seems to be the most recommended on here, what was your experience with A&E Leisure like. They seem to be a little cheaper as well unless they leave some bits off.
From what I can see, Emergency inflation in case of compressor or electronic failure is an option that SAP include. Any suggestions from anybody as to what spec to look for.
I was going to look at Goldschmit like Lenny HB has but Germany or Belgium seems a long way if there is a problem. For us SAP is 2 hours away, A&E 1.5 hours and Sporttec just over an hour. So not a great difference, but the best job and support is the most important. Thanks for any feedback.
Sep 17, 2017
5,520
10,317
Birmingham, UK
A-Class
I went to A&E Leisure to have my VB 4C Full Air fitted. They generally did a good job. But I have had a couple of issues. It rides lower than I'd like (which may might not be able to be helped), the waste tank had to be moved and now it doesn't drain as well, and the water level sensors (which use an odd digital signal) is now flakey. My main issue though is that they've positioned the ride height sensor where it squashes a pipe for the air heating. I think it interferes with the leveling on that corner when it's squatted down.
Sep 17, 2017
5,520
10,317
Birmingham, UK
A-Class
Did they fit the spacers on the rear which raises it 20mm?
I don't know. But the front is lower than before and the rear is much lower. It used to have a lot of rake, so having it almost flat all the time is convenient. Except it's low enough to scrape it's belly on speed humps. I'm not sure where that default position is in its range of travel. The ride comfort is much better than the standard Fiat springs, but it can tend to nod the front a bit like it's under damped.
Oct 15, 2011
4,190
11,382
Not Glasgow
Carthago chic eline
Since 2011
Hi,
I got the full package at A&E Leisure that included the self levelling and emergency inflation for £8300 as against £9000 at SAP. The difference covered the new alloys plus a tyre and a bit. 😜
They stated 3 days to do the job but had it finished in 2, they always cover themselves in case of problems arising but our van being almost new it was easier. Very friendly family owned business and gave us good discount on other items we bought. They book you in the night before at a local campsite free as part of the install. 👌🏻👌🏻👌🏻
OldAgeTravellers
1,212
1,395
Telford, UK
Since 1970
Hi,
Hi,
Thanks for the reply, sounds like you are pretty happy with A&E, I must admit that I was a bit concerned by the Guigsy reply above as I really do not want it any lower but want to be able to level a bit when on a slope to avoid levellers. At the show yesterday they said about 750 to 100 mm movement which is about the height of our old yellow Fiama levellers. And when he said that they moved his waste tank that set alarm bells ringing with me.
Did you have the standard alloys before or uprated from steel rims? I have been told that with the VB system fitted I should be able to uprate the van from 4.5 to nearly 5 tonne if I fit 12 ply tyres but not sure about the original fitting Hymer alloys I have on the Hymer on the maxi Ducato chassis.
I also am actually not clear where they can fit the compressor and air tank on mine as I have the double floor and really don't want to lose that storage. Where are yours fitted?
It's a large outlay so I had better phone SAP & A&E next week to find out what their suggestions are. My Hymer is 2012.
Lenny HB
53,648
150,797
Hymer B678 DL
The standard Fiat alloys are 1250kg I don't know what the Hymer ones are you would have to ask Hymer.
It will fit underneath between the chassis legs, it's not very big nothing will be fitted inside.
Sep 17, 2017
5,520
10,317
Birmingham, UK
A-Class
My van is 6m Fiat chassis with no double floor. So the underside is pretty busy. They slightly moved and notched the waste tank to allow the new suspension members free movement. The compressor is hidden in an internal cavity, but the small tank is external and forward of the exhaust with a shield.
It's low, but to be fair, I've only kissed a couple of speedhumps. It was always low, but now it's a bit lower. It does still have a fair range of movement to adjust for slope. It seems to prioritise front-back slope more than side slope though. So we have once still used a single ramp. I've also used it on a very gnarly and steep sheep track across a private field in the Lake District in raised off-road mode and it was fine.
I don't regret getting it as it makes driving more comfortable. Most if the time we don't need ramps when previously we'd use them about half the time.
OldAgeTravellers
1,212
1,395
Telford, UK
Since 1970
I have a spare that is also alloy so it may have it stamped on the inside of the rim, job for a fine day as I have to empty the garage to get to it.
The only chassis space is behind the rear wheels so even more important to uprate it as with the scooter on I am at the limit.
