- Sep 28, 2017
- 87
- 24
- Compass 180 Rambler
- 2017 Just started as Retirement looms in August
Well I’m glad asked , so operating it from my set up is out of the Question, 2 lead 130a batteries and 200w solar panels which for the telly and other bits does me fine , I assume if hooked up on sites here and Europe the Unit would work ?After sweating like I don’t know what in Spain last summer I’m thinking of getting Air Con unit , seen a Truma one for around £1500, anybody got that one or can recommend one, I want one that will run of the 24v inverter set up I have , looking for advice
thanks
I think that is the cooling capacity in watts not the power drawn in watts which is a lot lower. Check for the power consumption figures. Won't be as bad as that.The Truma unit i just googled was 2400 watts. (2.4kw)..
Just checked and. 4.2A x 240v = 1,000WattsThe Truma unit i just googled was 2400 watts. (2.4kw)..
So that over 10 amps on mains EHU and 125+ amps on 12v.. !!!
Not saying you cant do it via an inverter but would most likely cost more than the AC unit. Lithium batteries, solar, DC charger, large inverter etc.
Another factor is the noise, seen many posts where people cant sleep because of the heat, then fit AC and can sleep because of the noise![]()
The same is the issue with heat pumps. People keep talking about the cooling power not the electric consumption. You are not alonePhew.. well spotted. See I know naff all about AC.. Just find a bar that already has it installed.
Yes they can be. Apparently the Truma has a night mode setting, which makes it quieter.They are a bit noisy to use at night and to a point during the day, thats why ours is mounted at the back of the van.
I agree with most of that but 7000 watts of solar is very impressiveWe have as previously posted the Dometic Freshjet 2200. This runs quite happily from our Victron 12/2000/80 inverter charger. Although we only have 200 amp of lithium with the 7000 watts of solar, we manage very well if the suns out enough to need the A/C it’s out enough to keep the batteries up. The trick is not to try and turn the van into a fridge. We find set at 22c it keeps the whole van (7.5 mtr A class) comfortable. We have it mounted in the rear bedroom with the fins pointing forward during the day then just shut the bedroom door for a little while before going to bed. This A/C runs quite happily from a 6 amp supply when on the rare occasions we are on hook up. And if there is only 4 amps available as we have found on some Italian sites we just set the inverter chargers input limit to 4 amps and let the batteries share the load. They are a bit noisy to use at night and to a point during the day, thats why ours is mounted at the back of the van. The power side to use off grid was not cheap but boy are we grateful when it is needed. From the outside it is just a light hum and even on closely packed sites not had any complaints just a few enquiries as to how can we run it when no hookup available.
I fitted the compact. But you can’t run off-grid without huge battery and solar.
Opps! 700 wattsI agree with most of that but 7000 watts of solar is very impressive![]()
I have 2 x 100 amps Transporter Lithium together with 700 watts of solar can manage around 6 hours if it’s warm enough to need the air con the suns out enough to top up the batteries. But again its as long as you don’t try to turn the van into a fridge. We still close the blinds on the sunny side. And cover the windscreen if its reallly hot.I fitted the compact. But you can’t run off-grid without huge battery and solar.
I’m 20 mins from audenshawe Allenaah if you want y to come and take a look.
I’m in hospital at the moment so it will be a few weeks before you can come over.
We have the Truma but only off EHU....very good at cooling and does this very quickly.After sweating like I don’t know what in Spain last summer I’m thinking of getting Air Con unit , seen a Truma one for around £1500, anybody got that one or can recommend one, I want one that will run of the 24v inverter set up I have , looking for advice
thanks
That’s what is good about the ducted units. It’s under benchThe think with the roof mounted air con, is very inefficient, you want the external unit in the shade, not in the blazing sun. Thats why eats so much power. A house mini split, with the external unit on north side in the shade, will run 10-15mins at 700-800w then throttle down to as low as 350-400w, just to maintain the set temperature. And thats a even bigger AC.
I have seen an American dude on the tube, fitting and then operating, a underslung external AC unit, with double fans, all protected and sealed . It runs on 12v dc, no conversion needed, 9000btu max cooling and 800w max draw. I think the cost was about $1500 from china.
Yes, but the heat exchange unit should still be outside so the hot air does not get recycled to be cooled again. Unless it has at least a hot exhaust out.That’s what is good about the ducted units. It’s under bench
Stand alone ARE very noisy, in the house you want a proper split unit. That way the noise and heat is kept to the outside.We have the Truma but only off EHU....very good at cooling and does this very quickly.
No air con will ever be quiet, we have the stand alone units in our house which are noisier I'd say than the fixed one in the van
