Air bag warning light (1 Viewer)
Jan 28, 2016
2,521
2,959
Stockport, Cheshire
Bravaria i740 AClass
Help
Just given the moho a run fiat ducato and the warning lights for the airbags has come on.Red light saying failure and amber saying de activated. Amber maybe that just the warning light is faulty how can you find out without going to garage?
43,435
50,313
Two definate ways to check.
1..drive into a wall at speed... No airbag deployed, lights working correctly
2..have system checked by suitable diagnostic equipment.
Other than checking plugs etc there's nothing you can do yourself
MikeD
3,936
3,697
London
IH PVC
Modern Fiats seem to have a designed/build in defect of showing warning lights.
Are they well alight or just glowing. When our dash failed they just glowed.
Fiat replaced it under warranty. (y)
Buster30
90
32
Derbyshire
Hymer Mercedes ML580
Since 2018
As above, it is generally the seat belt attachment
Simon Meadwell
Jan 28, 2016
2,521
2,959
Stockport, Cheshire
Definitely glowing properly as if a real warning its just the uncertainty of the problem
1. No airbag or
2. The warning light is faulty ?
43,435
50,313
I don't see how it can be faulty warning lights when both are lit.
It's my opinion the bag activation mechanism/sensor has failed and as a result it has been deactivated to prevent possible unintentional inflation due to a faulty sensor.
Activation mechanism/sensor failure could be something as simple as a broken wire or unplugged connector
jimcunliffe
46
26
Bacup,Lancashire
21/2 years
We had the same issue, fiat diagnostics said airbag Ecu so £172 for the part and £85 For coding and still the same, turned out to be dirty/bad connection under passenger seat!
