Thanks for this ! I have read that a leisure battery subject to a drop test should be disconnected for at least two weeks before starting the test as a good battery will hold its charge for weeks if not months, yet a battery with limited capacity will still hold a full charge for quite a while after being fully charged and doing a drop test within a short time after charging will give a false result. Do you agree with that premise ?First charge the battery fully and leave it to settle for an hour then:-
For example if it's a 100a/h battery load it with a 5 amp load and run for 5 hours, this will represent a 25% discharge. (adjust load/time to suit the size of the battery)
Disconnect the load and leave to stand for at least 30 min then measure the voltage.
Repeat the test and you will have discharged the battery to 50%.
You can repeat again then it will be 75% discharged.
Always best to test each battery individually if in any doubt.
