NickandClair
... we've found discrepancies between the on-board monitor, multi-meter and a little one that we stick in a ciggy socket, consequently we never really know which to trust so always err on the side of caution and go with the lowest figure, however it would be nice to have one that accurately reflects the remaining capacity of our battery bank ... what would you suggest without spending a fortune?
Also, with a Euro 6 (2017 or 2018 build) Fiat Ducato based PVC what benefit would having a B2B give that the existing split charging system doesn't? I've got another thread running about our power needs and looking at getting a genny, but obviously if there are other things that will help I'm willing to investigate further!
https://www.motorhomefun.co.uk/foru...erate-power-mechanically.189780/#post-3158464
I'll go and have a look at your thread @Minxy Girl , rather than go slightly off topic here.
Don’t listen to anyone that says running your Fiat on tickover won’t end in tears !
Even for short periods of time
We know from our own experience and several others it’s just not worth doing.
With regards to running your engine on short periods. I am sad to hear that you have had DPF/Re-Gen issues, but there are literally thousands of Welfare Vehicles, Ambulances and other service vehicles, whom have no issues in running vehicles on idle for short periods. You also have to bear in mind that in normal situations, you would be at an Aire/W-Camping site for say 2 days and then undertake a 2 hour drive down the road. Current split-charge systems on most British/Euro built vans are done with small diameter cable and a 30p relay soldered to your distribution unit which puts a lower ah capacity engine battery in parallel to your higher rated ah leisure batteries, meaning that if you were relying on the standard split charge system, it would take hours of engine running time to recover the batteries to full. Using a B2B/DC-DC chrager uses much thicker cable and harnesses the available power from the alternator and charges the leisure bank to it's correct AH capacity in a much shorter timeframe.
