Advice on air con and generators please!
TheEscapist
I’m a newbie
Hello Everyone
I’m looking forward to contributing to the forum and most of all, learning a lot...
I’ve just bought my second motorhome, a Carthago Liner for Two 53.
Previous one was a Bilbo Camper 30 years ago so I’m really a newbie...!
The Carthago comes with most things but my concern is about self-sufficiency. I want to te off the beaten track. I know the Liner for Two is hardly an all terrain survival vehicle but what I’m looking for is a comfortable life but with independence.
To this end, I’m wondering about air-conditioning and generators.
I think the water (200l) and grey water (185l) are enough.
I’ve specified a third leisure battery and ordered solar panels.
The engine is a 2.3l Fiat Ducato uprated to 180hp and the chassis uprated to 4,800kgs. The diesel tank is 90 litres so at around 30mpg I’m banking on a range of around 600 miles.
So I figure I’m all sorted except I wonder about the whole relationship between the engine charging the three leisure batteries, the solar panels charging the batteries in the daytime (apparently they are the type that work in all weather not just sun), using appliances at night, and then when I’m in hotter climes, using air con and the need for a generator.
I think I would be fine without a generator with sensible evening use with electricity from the 3 batteries but when I use air con the batteries won’t support it.
So my choices seem to be plug in at a site or use a generator. For when I’m not on a site, what size generator would run the aircon for a night and would it not be too noisy (I’m guessing not in the scooter garage).
Also, how should all the abov be word together?
The dealer says they have never fitted a generator so I’m wondering if I’m overdoing things or whether this is a sensible option.
Yanks in advance for helpful advice from you all.
Best wishes
Paul
If using the van mainly in mainland Europe fit 400 - 600 watts of solar on the roof with a good quality MPPT regulator.
And if still worried about power fit lithium batteries.
The OP will need a friendly Bank Manager for that lot .. :D2 :)
Can you please tell me where I can buy these MAGIC Panels that don't need sunshine to work ..
@eddievanbitz sold me two panels for £500 said they work a treat at night. Lunar panels he called them. Brilliant (y)
Some misunderstanding, I think. He actually meant that lunar panels work great ON the moon. No clouds and less atmosphere to reduce the sunlight.
No no, Jim has a pair of our new lunar panels fitted to his van.
The term ‘lunar’ is confusing, they work all the time, just better in moonlight or sunless, cloudy days.
The brightness of the moon is about 13.6% of the brightness of the sun. So a 100 watt solar panel would be a 13.6 watt lunar panel. So 300 watts of solar panel would be about 40 watts of lunar panel. Not very much, but better than nothing.
Sadly being "Lunar Panels" ours tend to abscond on Full Moons! Don't know why! or HowwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwL
That's nonsense, where does this clown get his figures from:(? That's the value of the reflected light on the moon.
On the earth, due to the distance, if it's a full moon, a 100 watt panel will be about 1 milliwatt, which is effectively zero for practical purposes.
Hello Everyone
Best wishes
Paul
Ignore the "humorous" parts of the comments above but note that you seem to have been given some strange information by your dealer.
A generator will struggle with a/c plus all of the other demands and won't be quiet.
Where are you planning to visit for your holidays and what times of the year will you be away?
I have to agree about generators its one of the 2 things that upset most people the other is yappy dogs.
If you really want the air con why not first choose one probably dometic .go to a site that sells them it shouldtell the start up power needed will be possibly 2kw that will give you genny size.
I would have one if i didnt have other priorities
Without doubt the Endless Breeze 12Volt Fan by Dometic is the way to go. We have had them fitted (did it myself) for 4 years now and even in Spain at 30C+ in August we can enjoy life inside the MH as can the cats all day and sleep well at night. Bedroom vent draws air in - Front vent draws air out at night and reverse during the day.
Model name corrected.
The Endless Breeze is freestanding
Do you mean Fantastic Fan?
As QFour says, running a generator at campsite would be the very last of the last choices and only then in an emergency type scenario. It just pisses everyone else off around you.
Spend the money you would have invested in a genny on more solar panels and more batteries..
Or go Lithium if you have a few more quid to throw at it.
Bit concerned with the video as i didn't see him put any supporting framework between the inner and outer roof skins if that is the case he can look forward to leak problems very quickly
I used the video purely as a visual aid.
I fitted mine and so far no leaks and trust me when it rains in Spain it rains.......
View attachment 288096 View attachment 288098 View attachment 288099 we toured France with a Honda 2kw Genny running 8000btu amcor freestanding air con unit ducted out through 6" hole cut in floor. It ran for 8-10hours on a tank full of petrol and kept us inside at 22degrees when it was 34degrees plus outside. My wife had been treated for breast and neck cancer and had a PEG feeding machine and portable oxygen. We have wonderful memories of driving into Monaco and parking next to the marina. We lasted 4hours before the police informed us "no camping cars here"
Hello,
I now it's beed 6 years since this post but if you could tell me please
Did you use genny and portable aircon while driving? If yes, has it affected longevity of portable air con (potholes ect)?
Regards
R.P.
Yes I’m hoping I don’t need the aircon but the level of insulation and underfloor heating in the home makes me think I’ll be hot rather than cold!
You don't seem to understand insulation then.
It reduces the flow of (thermal) energy in both directions.
Don't cook in your van, one of the reasons why Continental models tend not to to have a full oven, I believe.
Use an extractor fan or skylights to allow heat to escape at night.
We have a maxxfan works a treat on that score.
Hope this helps.
