I'm assuming it's a hatch so you can access the distribution box?
Nope minxy got it rightSafe ?
Safe ?
How often do you trip the electric.Yup
Instead of having to lift the whole bloody shelf the edge of which is under the bed so a right bloody mission when it trips....
Hence easy access hatch.
Don't think we have ever done it
I will sort that shortly for yoiLike the hatch, got a link to what you bought?
Things I’m looking for at the moment if anyone has any tips...
1. White plastic organiser for the shelf under the bathroom window. I think that’s 7cm deep, though need to remeasure to be sure.
2. Bin - what do people plan to do?
3. Step. Though I can get into bed it’s pretty high if you’e 5’ 2” soaking wet. I think either something light and foldable or a very strong box that will serve dual purpose as storage and step.
4. What to do about the blinds at the rear doors? We want to sleep heads that end, but I’m a bit concerned about damaging the blinds. I could remove them and make my own blind with pockets for iPads, kindles etc which would be nice.
5. Shower storage is woefully inadequate - just enough for a bar of soap. There is enough of a gap between the top of the shower and the clever folding door thing to add something. Thoughts so far are something to hook over the door (but it’s very wide and the little plastic basket I got from Ikea didn’t work) or a suction hook and hanging wash kit or suction white plastic basket, which is probably my favourite, only needs to store shampoo, conditioner, hairbrush and razor.
I'd go for something that won't be affected by moisture, ideally with a lip to stop stuff dropping off if you're on a bit of a slope, if you go for one with a high 'lip' you would be able to leave stuff on it in transit. Whatever you get think about how you'll fix it as attaching it to the van side won't be possible/easy so support brackets at either end into the cabinet sides is the way to go.Things I’m looking for at the moment if anyone has any tips...
I put one under the end off the offside bed, works a treat, not in the way but easily accessible ... but see below for an idea!2. Bin - what do people plan to do?
I thought it had steps already? Ah, I've just managed to see a photos, there's quite a bit of space between the top step and the bed ... I'd go with a box half the width of the top step, in effect a third step, you could actually make this your bin. If you make it so that it is held in place with Velcro if you need to remove it you can.3. Step. Though I can get into bed it’s pretty high if you’e 5’ 2” soaking wet. I think either something light and foldable or a very strong box that will serve dual purpose as storage and step.
I have insulated pads that I can use if I want to sleep that way (like the usual windscreen internal pads). Alternatively put some bars across to rest against, or make removable headboards held in place with Velcro so they don't drop out when you open the rear doors!4. What to do about the blinds at the rear doors? We want to sleep heads that end, but I’m a bit concerned about damaging the blinds. I could remove them and make my own blind with pockets for iPads, kindles etc which would be nice.
Have a look at B&M (or is it Home Bargains?), they do small suction clear acrylic type plastic baskets, about 69p ... they are very good and don't drop off! Or look on Ebay ... for plastic shelf/baskets ... there are loads to choose from![/quote]5. Shower storage is woefully inadequate - just enough for a bar of soap. There is enough of a gap between the top of the shower and the clever folding door thing to add something. Thoughts so far are something to hook over the door (but it’s very wide and the little plastic basket I got from Ikea didn’t work) or a suction hook and hanging wash kit or suction white plastic basket, which is probably my favourite, only needs to store shampoo, conditioner, hairbrush and razor.
Ah, mixing you up with that ruddy cat funster (@Cheshirecat57 )Hi @Minxy Girl - will read all that lovely detail layer! The van is actually the SGX with the raising bed so it’s a fair bit higher.
