My van im collecting sunday has a single factory fit Truma 100 watt lightweight flexible solar panel with associated solar controller. I want to add 2 more panels. Can I just daisy link these together to the last point before the power heads off down to the controller or is it a little more complicated than this so each panel doesn't throw power to other panels?
Also I have a single 110amp battery located under the floor. Its a 2021 van so all modern. Would I need to look deeper at the charging units etc before I swap it out to a Lithium battery?
Finally to add an inverter system do I tag that direct from the battery then back to the mains domestic unit with a switcher box to select on board inverter power or EHU? Or again is it a bit more complicated than this.
TIA.
TIA.
