Adding a WiFi mini breaker (1 Viewer)
Jan 2, 2012
111
32
Bristol
Knaus Van Ti 640 MEG
Had a variety of tents, tipis, motorhomes, caravans and now back to a coach built motorhome!
Is it possible to add a WiFi mini breaker to my motorhome consumer unit so that I can remotely turn off and on my Victron 15a blue smart charger? It’s not possible in the victron app.
I did look at a WiFi fused spur that I could use to do this but that’s quite big and bulky and then saw that WiFi mini breakers were a thing.
Apr 27, 2016
7,383
8,786
Manchester
A class Hymer
Since the 80s
Looks like you have space on the DIN rail next to your other circuit breakers, enough to fit one or even two of these. They clip on, and can be easily unclipped with a screwdriver to release the clip.You may have to cut a bit out of the cover to allow it to go back on - the section required might simply break out.
It has a lot of extra functions (timing, metering etc) so you may be able to find a cheaper one that just does on/off.
Two on Tour
10,793
55,676
Elddis Autoquest 175
Since 2010
Why do you physically want to disconnect your Victron 15a blue smart charger ?
If you then re-connect your solar charger without first disconnecting your solar panels, then your Victron solar charger may auto select 24v mode as I understand it as it senses the voltage your panels are producing.
You can stop the Victron Smart Solar chargers from producing an output via the Victron Connect app by toggling the "Charger Enabled" option in the "Battery" menu.
DaveS
Jan 2, 2012
111
32
Bristol
Its not the solar one, its the mains charger and you can't turn it off like you can the solar controller. My inverter has an auto pass through and when on the inverter I need to keep going in to the garage to switch the mains charger off when the consumer unit is powered by the inverter. I have a manual switch at the moment, I'd simply like an electronic switch to make life easier.
DaveS
Jan 2, 2012
111
32
Bristol
Look on Amazon for a remote relay switch. Inexpensive and work well.. or a remote socket switch which sits between the plug of your charger and the socket it’s connected to. ✔️
Edit: would this work for you?
Not really as the charger is all hard wired in to the consumer unit. I think the wifi mini breaker is the neatest solution.
DaveS
Jan 2, 2012
111
32
Bristol
Perfect thank you, I think that's exactly what I'm after.
