- May 16, 2021
- 1,280
- 1,755
- Autotrail
Bolt with (nylock) nuts will be secure but a faff to both secure and remove if using in conjunction with stuck down mounts
Pop-rivets will rust and work loose just as much - and probably more so - than screws.
I would - and always do and have - use self-tappers (into a pilot hole) if going directly into the frame. These are secure, reliable and are easy to check when you are doing your general periodic roof checking and if need be replace.
