Curious here, i want to do the same thing, connect additional battery next to one under the seat, i saw another post saying you should add a fuse like this http://www.motts.org/second leisiure battery.htm. Thoughts?
Thanks for that, that's this weekends possible job, I have the cable, and did buy an in-line blade fuse holder, but was pondering it's use. My logic was, I cannot recall seeing a fuse in between terminal links on banks of batteries in fork lift trucks ect.Personally if the batteries are right next to each other I would not add a fuse to the link wire. You already have a fuse on the main positive output, close to the battery. However I'm sure others on here would disagree. If the batteries were widely separated that's a different matter, a fuse at each end of the link wire is required.
Very expensiveThere is a table somewhere that tells of length to thickness needed.
These sell cables and crimping etcAuto & Marine Electrical Components & Accessories | 12 Volt Planet
Huge range of 12v & 24V wiring products, components and accessories for vehicle electrics, marine & leisure electrical projects. FREE delivery on orders over £100www.12voltplanet.co.uk
