Abs warning light
Alonsos
177
15
Devon Somerset border
Auto trail t615
Since 2008
Fiat Ducato x250 Mondial 2010
I've got the ABS light coming on (not full brightness) it's very dim ( can't see it in daylight) only when it's dark,
When parked & turn on ignition then turn off again the window buttons light along with dim ABS these both go off after 3 mins
When driving dim ABS light on (again not as fault but dim)
Anyone else got this prob or is it off to garage diagnostics computer ??
Could be a simple earth fault from the relay which controls both.
Should the diagnosis be a new ABS unit, it should be possible to get it repaired, which will still be expensive but a lot less than a new ABS unit. Hopefully the problem will be something more minor but ABS units do fail.
Go to van , turn on ignition , turn off ign, all illuminated items and abs go off after 3 mins ( not started van cold van & engine)
