A warm hello from a family looking for advice on their first fifth wheel! (1 Viewer)
vorneus
3
3
Don't own one yet
I'm a newbie
Hello everyone,
My name's Ed. My wife and I have been wanting to purchase a pickup and fifth wheel for camping around the UK ever since we RV'ed in California for our honeymoon (4 years ago!).
This year we've finally got to a position, financially and with our young daughter who is now 3, where we could actually make it happen and so I've been doing research and having a look around various places for what might be a good starter setup for us. My current thoughts are that a Kountrylite rig and a Ranger/Navara/Hilux would be a safe bet, but ideally I'd love to hear from people with first hand experience to impart some wisdom!
We're almost certainly looking to buy second hand, and were looking to spend somewhere in the region of £20,000 on the combination. As for how that is split between tow vehicle and rig I'm not quite sure, as I've heard conflicting advice!
Any pearls of wisdom?
Many thanks to all for reading,
-Ed
TCG
Jul 6, 2017
1,364
2,044
Salford Priors
Autotrail Delaware
welcome - your budget looks really tight to get both the tug and the van for 20k but good luck with your search
Jun 12, 2016
1,621
4,358
Scottish Borders
Globecar Revolution
Since 2006
Have you the right category's on your driving licences?
Agree your budgets a bit tight
Make sure there are no damp issues most other things can be sorted fairly easily
V
vorneus
3
3
Don't own one yet
I'm a newbie
Hi everyone - thanks for your replies!
Yes I'm aware budget is tight, but Ive seen a few used Kountrylites (2008's, etc.) for between the 7.5k and 10k mark so that's what I'm looking for. I could definitely stretch upwards to avoid making a duff decision though! Good advice re. damp Garfields so thanks for that - and re. driving licence not yet, but I'm aware of what I'll need to get.
To those who have said budget is tight, would you be able to suggest what might a better / more realistic budget to get started? Like, what I should be looking at in terms of cost for a tow vehicle and trailer - them both being second hand is a given. Or alternatively I could look at hire purchase for the tow vehicle to release a bit more to spend on the trailer.. lots of possibilities!
Thanks all,
-Ed
43,367
49,719
B+E is all you need depending when you passed the test.
When all said and done it's only a car and caravan.
The only restriction is the tugs train weight and the weight of the van.
43,367
49,719
Category BE
You can drive a vehicle with a MAM of 3,500kg with a trailer.
The size of the trailer depends on the BE ‘valid from’ date shown on your licence. If the date is:
  • before 19 January 2013, you can tow any size trailer
  • on or after 19 January 2013, you can tow a trailer with a MAM of up to 3,500kg
Either test date will be OK for a lightweight 5th wheel... And the Kountrylite will be well under 3500kg, probably nearer 2000kg
Wombles
10,814
11,140
SW England
Van Conversion
A few years now
Hi & welcome! :hi: Would also suggest joining our sister club RVOC www.rvoc.co.uk to help with advice that you are looking for.
Minxy
32,695
66,727
E Yorks
Carthago Compactline
Hi Ed, welcome to the fun house.
I'm intrigued, other than you using a 5th wheel set-up in the US, what made you decide on one for the UK instead of a car/caravan or motorhome?
TheBig1
17,644
43,459
if you are on a tight budget, be careful if you choose the navara, the early ones were great tow tugs but the chassis rusted quickly leading to several snapped chassis. Nissan did a recall on them last year and took each one in, removed the rear tub and checked the chassis before repainting it and returning 2 weeks later. Unless it was cracked, then it needs to be shipped to Spain for repair, which takes many months. Or Nissan just wrote you a cheque and bought it back off you without negotiating.
just check that the navara has been through testing/repair and is ok. A good check is look at the chassis by the back wheel under the tub, if it's rusty walk away
by the way, mine was fine and the dealership commented on the great condition for a 2008
2657
Category BE
Not so for the weight of the Kountrylite, my low profile model weighed around 3500 in touring trim.
Figures were:
Pickup solo with driver and passenger..........................................2100
Pickup axles on weighbridge with 5'er hooked up...................2950
5'er axles on weighbridge...................................................................2980
Giving a gross train weight for the rig of 5930
MGW of 2008 Mazda Bt50(Ford Ranger)......3030
MTW...........................................................................6030
So not a lot to spare on either weights.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Take great care when purchasing an older European truck, especially one with a box section chassis. They are prone to rot from the inside out as many of the double cabs have been used by the boat/jetski/surfboard brigade for launching. Also bear in mind that Euro trucks are much narrower than American fifth wheel trailers making it difficult to see down the side of the outfit when manoeuvring.
funflair
19,426
30,572
Guisborough
MORELO palace
since 2012
I am wondering why a 5th Wheeler rather than a RV or European motorhome, if you want to travel abroad are you welcome on the airs and stellplatz in these?
Martin
Oct 2, 2008
4,486
7,996
Salopia
Duro 6x6 Overlander
since 1968
Advantages of 5ers over car caravan , more stable towing, slightly easier to maneuver, larger floor area for oal .
2657
Possibly in certain circumstances but the big disadvantage with 5'ers is that they cannot be dropped and moved into position by the use of motor movers which is important on many sites in Europe, especially older Spanish sites.
I know others have said that they never had a problem with this but with nearly 50 years experience of driving articulated vehicles and similar with caravans, also 10 years experience of towing a 5'er in Europe I think that I can speak with some experience.
Oct 2, 2008
4,486
7,996
Salopia
Duro 6x6 Overlander
since 1968
Thats why I put "slightly" in the same way as moving a caravan with a front mounted hitch on the tow vehicle . We would appear to have same driving experiences except I would replace the 5'er experience with 12mtr RV :)
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
I am now running my second fiver having owned one before. The reason I went back toa fiver after running several PLGVs was that I did not want to go down the medical route once reaching 70. The crazy part about it is, I can run a 30ft 3 slideout fiver and towtruck on my ordinary car licence, whereas a 30ft 3 slideout RV towing a trailer with car on would require me to renew my HGV.
One more aspect, id that on long term trips, I can leave the fiver on a pitch in Europe and nip back home in the donkey, saving a considerable amount of brass on the ferry. Just maybe thats how I managed to retire at 50.
V
vorneus
3
3
Don't own one yet
I'm a newbie
I think we just really like the idea of them really! Having a second utility vehicle in the tow truck, the whole american style of the trailer we love, and the fact that it's less common and we'd just enjoy the whole experience!
Thanks Snowbird for the sound advice re. older rigs and rot - I've heard this from a few new!
We're currently debating between the relative positives / negatives of buying second hand outright vs. a new rig on finance. Tricky!
Thank you to everyone for such a warm welcome :)
-Ed & Kelly
Feb 18, 2022
150
147
Suffolk, UK
Rapido 9048DF 2016
Currently staying at a site with a few 5th wheelers which look to be permanent.
They are large.
This made me think about this as a possibility.
I've given up my licence for over 3.5 tonne at 70, but I came here to check that you could treat this as a trailer.
For example pickup which can tow 3.5 tonne and up to 3.5 tonne 5th wheel.
From threads here it looks as though you can.
We did have a 2 tonne Hymer caravan and still have the W Touareg which can tow a 3.5 tonne trailer but I haven't seen a 3.5 tonne caravan!
I note this part of the forum is very quiet.
CAB96
778
1,615
Stockport, UK
T6 Leisuredrive
They are large.
I would imagine you now benefit from the relaxation in towing limits, which wasn't the case when the OP was looking.
I wonder if they ever bought one?
