hilldweller
What do you guys think of this panel?:thumb:
Not good.
If you glue it down and the roof or the panel needs service what do you do ?
Not good.
If you glue it down and the roof or the panel needs service what do you do ?[/QUOT
Hi Brian
So I'd have to glue it to something removable, and so defeats the objectoh:
Tim
Not good.
funnerly anough brian,i could almost feel you breathing down my neck when i was trying to help this guy out,but did wait awile,because i noticed you logged on and thought you might help him:thumb:It means that, as is quite normal on a forum, someone gives inaccurate or partial advice.
im saying that if it was pointing at the stongest brightest sun it would produce 3.41 ah so over a 10 hour day 34.1 ah.
on a dull day 1/2 ah.???
p/v solar is a better option per watt:thumb:
Shall I put this right....
The panel will output 3.41A. No h.
3.41A over 10h is 34.1Ah - this meaningless.
p/v is better..... They are all photo-voltaic - latin - photo = light, voltaic = volts. There are 3 types of cell, monocrystalline is the most expensive with best output ( ignore amorphous and polycrystalline ).
Now back to the 3.41A. He missed the 43V peak. This tells me it's designed to work at about 36V. The controller will take in 36V at 3A and convert it to 12V at 9A ( approximate figures to make it easier to understand ). That 12V at 9A = 108W is in line with their sales figure.
But you never get anything like that 100W in the real world.
And the "h" that keeps creeping in. That is connected with time to charge or drain the battery. An 85Ah battery, will provide 8.5A for 10 hours. Yes ? NO. Because you can't take a battery down to empty without killing it that 10 hours is dropped to 5 hours for a normal battery or 7 hours for a deep discharge battery.
Back to your 100W panel. Take a guess at 50%, 50W. Your 85Ah battery is half discharged so you need 45Ah to go back in.
50W from panel. 50W / 12V = 4A
45Ah needed so 4A for 11h does it. But when do we get 11h of sunshine :Sad:
[ All number have been simplied to make it easier to understand ]
Hi! Ralph, what sort of price are these batteries?
Cabbyshack
but fair play you caught me out, :thumb::thumb:
but a lesson learned on my part,cheers teach:thumb:
i just also noticed that im the one only pulled up???intresting?
