wotme
There are times when I think my son-in-law should be shot but he happens to be doing a good job right now looking after my daughterThe bloke should be taken out & shot. .
But don't prod too far or too heavy I've seen evaporators punctured doing that. Most evaporators require dash removal to replace.I think the worst problem with vehicle ac units is the condensate drain. That blocks up and the first you know is a wet splash on your foot!
There is usually a rubber drain tube that comes out underneath the vehicle near the bulkhead. Worth proding it with a bit of wire to make sure it is clear if you are ever under it.
That makes sense, I'll take that on board, cheersThe smells on vehicle A/C tends to be caused by bacteria growing in the vent system of the A/C not the A/C it’s self. .
I was recently offered a business opportunity for supplying/installing a clever bit of aftermarket air-conditioning kit.
Had to decline but it does look like a cost effective alternative to the normal Air-con systems.
Check it out Here.
Glad I didn't go down that route then!You may as well have thrown your money away with these. They work in very dry and very hot conditions and nowhere else.
Think of it like a fan passing over a bowl of water, not exactly high tech or effective.
