3D Printing. Is it UV and Heat resistant (1 Viewer)
Nov 8, 2020
688
1,371
Harpenden
Auto Trail Comanche
This is a question I have asked myself many times.
3 years back when I knew very little about how 3D printed materials would last in the sun, i started a little experiment to really test ASA filament which is used in 3D printing. Would it last last. ?
This was a test for UV and severe heat from a Truma boiler flue.
I made a replacement cowling with integrated deflector and watched, expecting the cowling to just gradually deform and fail. Well. 3 years on, this 3D printed cowling is still in the same condition it was when first made it. So the answer to the question, will it last. Most definitely it will.
So anyone thinking of printing parts for outside use or subject to heat. ASA is the the filament that can do the job. 3 year old part below.
Happy that it was robust and could take the abuse thrown at it from the boilers hot exhaust gases, I’ve made a new one incorporating design improvements I’ve learnt over the last 3 years making it look smarter.
Hope this was informative for funster 3D printing enthusiasts.
PaulandChrissy 👍
MisterB
6,773
15,584
Essex
Adria 670 SLT
Does 3D printing in ASA cause memory loss and an inability to finish sentences .... LOL 😆 😆
Seriously though, I think you're one of the most experienced on here, so if anyone would know, I'm sure you would .. (y) I know that you have helped me out a couple of times so thanks.
Jan 18, 2019
742
1,183
Cuesta Blanca, Murcia, Spain
Hymer Exis
Since 2010
View attachment 931744View attachment 931745
View attachment 931751View attachment 931752
PaulandChrissy 👍
If you've made and installed a "new, improved" version can you judge (non-destructively) whether MK1 has become brittle due to UV?
I find the plethora of choices of filament types bewildering, what with printer manufacturer's own consumables and 3rd party suppliers. It's inkjet cartridges all over again ...
PaulandChrissy
Nov 8, 2020
688
1,371
Harpenden
Auto Trail Comanche
I have given Mk1 version a bit of twisting and stress and it feels no different to the new Mk2. The makes of ASA I use is Prusa, Winkle from Spain or Filamentum.
Sunlu is another good make for PETG.
MisterB
6,773
15,584
Essex
Adria 670 SLT
I have been using a creality 3 pro and been happy with it and am considering moving up to an enclosed printer so I can print in ABS and also improve my prints
Any recommendations under £400??
PaulandChrissy
Nov 8, 2020
688
1,371
Harpenden
Auto Trail Comanche
My fat fingers pressed post before I had finished. Plus my hands have a tendency to shake. All part of the aging process
PaulandChrissy
Nov 8, 2020
688
1,371
Harpenden
Auto Trail Comanche
Make your own enclosure. It makes printer maintenance easier. Just lift your enclosure off for good access when working on it. As long as your printer has an all metal hot end you will be fine. I only have personal experience with Prusa printers. The only one in the £400 range is the Prusa Mini, but it’s only 180x180x180. If you’re going to try ABS, just go straight onto ASA. It warps less. Watching UTube reviews, the Bambi machines seem very tempting.
PaulandChrissy
Nov 8, 2020
688
1,371
Harpenden
Auto Trail Comanche
Fat fingers again. It’s Bambu Labs not Bambi. 🤪
MisterB
6,773
15,584
Essex
Adria 670 SLT
I'm tempted to follow your suggestion re building my own enclosure. I suppose it really only needs one clear side to see through, the rest could be plywood?
Is the top also enclosed, if so what about the heat generated and keeping the temp from overheating?
Jan 30, 2020
3,603
16,960
Mid Bedfordshire
RS Endeavour
Just a tad..
Computer fan cowled over the top?
PaulandChrissy
Nov 8, 2020
688
1,371
Harpenden
Auto Trail Comanche
I designed and printed the corners, and bought Perspex sheets pre cut to size. Plywood is just as good. Then just assemble it. Don’t worry about it overheating, it will find its own level. I have 2 printers in one enclosure that I made and it levels out at about 30-35c. Just perfect for ASA or ABS. Not a great picture below showing it, but it’s all I can find at the moment. The top is enclosed as well.
chesterfield hooligan
2,019
4,481
Hucknall, Nottingham, UK
Van conversion
10 years
Just seen this
PaulandChrissy
Nov 8, 2020
688
1,371
Harpenden
Auto Trail Comanche
Just seen this
I can’t get the link to work 😢
Jan 18, 2019
742
1,183
Hymer Exis
Since 2010
The Hope bikes that GB team are using in olympic velodrome are printed titanium. Made in Barnsley. £50k a pop if you want to buy one.
EDIT: Not Barnsley, Barnoldswick which, as any fule noes, is on the right side of the Pennines
705
1,894
New Forest, United Kingdom
N+B Arto 74C
The 3D printed metals are amazing, some of these metal parts are done by a process called Direct Metal Laser Sintering, very simply put the laser melts metal powder and it forms into the designed shape.
Every Formula 1 car has some DMLS 3D metal printed parts, also one of the airliners (cannot remember if Airbus or Boeing) has window frames that are metal printed.
Here is a part that I had done in aluminium.
And some parts from the recent 3D print show in Birmingham.
PaulandChrissy
Nov 8, 2020
688
1,371
Harpenden
Auto Trail Comanche
I’ve been watching these (Selective Laser Sintering) SLS printers. Still a bit expensive and they are very messy. They are getting cheaper though. Give it another year or two and someone will start making a hobbyist version at a good price. Very exciting. 😉
Mar 22, 2023
705
1,894
N+B Arto 74C
Just got a Flashforge 5M pro that is enclosed and gets good reviews, I will test this week. £395.00
Last night I set up the Flashforge Adventurer 5M Pro. The setup was straightforward: unpacked the printer, loosened the travel clamps, and loaded the filament.
The printer goes through a setup routine that takes about 8 minutes and is then ready to print.
In the video below you can see the first trial print taking place, I must stress that this video is not speeded up in any way, it is real-time. The speed and quality is unbelievable.
