PaulandChrissy
What printer did you get in the end.
ThanksYou will never stop learning. The art is getting a really nice finish. Might I suggest using Prusa Slicer v2.3 as your slicer program.
If that question was to me.... I got a Geeetech A20M - dual/mixer extruder at a reasonable price (for a starter machine). I suppose time will tell whether that was a wise decision; certainly the sample model supplied with it printed really well.What printer did you get in the end.
Good to hear! If I need something made I know you are pretty local and saves me the expense of buying oneI’ve now got my hands on a 3D printer
Bed levelling is critical with that machine to get a good first layer. Does it have automatic bed mesh levelling, or do you have to level manually.
I'd agree with Paul and Chrissy. I've a Prusa i3 MK3s and have made a load of things for my MH. I use Fusion 360 for design - it has a lot of functionality, but the learning curve is not too bad and there are a load of YouTube videos to get you started. Once you've built the model it's just a couple if mouse clicks and the printer will be making something. I'd definitely recommend Prusa products including their filament, which is superb.Hi ShaKen
There are loads of 3D printers on the market, all capable machines, but most need tweaking to get the best out of them. If you want a machine that is well sorted, good backup, and capable of printing for 1000s of hours, I would recommend a Prusa Mini. If you want to go to the next level, then the Prusa i3 MK3s. The printer is however only part of the equation. You need to learn a good CAD program. Only this way can you design your own thingymajigs. It is quite a steep learning curve, but once you master everything you won’t be able to stop making things. Don’t hesitate to ask more questions.
Hope that’s helpful. Paul and Chrissy.
Hi paddymcc, I got these from ebay, fit great and the guy does the fridge locks.If you do go into production ShaKen how about the lock on the Dometic fridge. Mine broke but I was able to repair it with superglue but a new one would no doubt be more durable. You can buy the lock for the more recent version online but not for my model.
I think that the OEM price is about £30 so there is potential profit in it!
No pressure![]()
Here’s my early results.....ShaKen put me on the list for the Chausson hook's when you are in a position to produce them.
Thanks Paul (or is that Chrissy).Couple of tips. In the corners add some chamfers, they take the stress away from the corners a bit.
Also looks like your flow rate may be a little low as you have little gaps between the layers. Also increasing nozzle temperature can help with strength.
Looking good.![]()
Slowing mm/s is just how fast the printer prints. The ratio stays the same. To fill those little gaps, increase the flow rate a little on the printer while printing. Hopefully you have a TUNE option while printing. Look for flow rate in TUNE on the printer screen. Loads of u tube videos you can watch to help you.Thanks Paul (or is that Chrissy).
Are you recommending I increase the mm/s? (I actually slowed it down thinking that it would give better quality).
Got it. ThanksSlowing mm/s is just how fast the printer prints. The ratio stays the same. To fill those little gaps, increase the flow rate a little on the printer while printing. Hopefully you have a TUNE option while printing. Look for flow rate in TUNE on the printer screen. Loads of u tube videos you can watch to help you.
