3 way fridge
Falmouth cornwall
Pilote p650
3 years
So been away three weeks. So far had new water pump, leisure battery. Now fridge is playing. Run while travelling on 12v.!!! Not working but should I have the light switch onto make it wrk?
If you have a RM7601L model fridge it is manual setting only and you need to select 12v setting on the selection dial (230v/gas/12v) for it to work , a green light on the dial by the12v setting should light up, if it is working, but only with the engine running.
If it's a manual switch, the 12V power is only available when the engine is running. Turn the switch to 12V. It won't work if the engine is stopped. When the engine starts, a relay inside the EBL switches the 12V fridge supply on.
The reason for this is that the fridge takes a lot of power (over 10A) and would flatten a battery in a few hours if it was accidentally left on. The EBL switches it off when the engine stops. The engine alternator can easily supply the power when the engine is running.
Yes I know how it works. No light when running the engine. Waiting for wardens to check the fuses. Ifnot need an engineer at nxt site
Which fuse was it? The one near the starter battery or the one in the Elektroblock (EBL)?
Well thkfully it was a fuse. Wardens didn't come an help at pensevey horrible site. Thk you all for your replys much appreciated.( I now know how to change fuses!!
I agree with you about the Pevensey site. Absolutely awful
I have marked it as 'Never again'
Geoff.
