3 way fridge not working on 12v (2 Viewers)
Aug 20, 2019
1,727
12,097
Dethleffs Pulse
Motorhoming since 2020
Help please. As we've just run out of gas our fridge has stopping running and we have just set off to drive for an hour to get gas thinking the 12v would kick in on the drive but the fridge is still flashing that it's not working. I even switched from auto setting to manually put it on 12v but it's still flashing. Engine running, batteries have plenty of charge. Any ideas? It's a thetford and is a year old.
Apr 22, 2018
6,843
12,620
Herts.
Adria Coral lowline
Have you turned it off then on again, as it may be just confused as you ran it out of gas, before switching across.
Aug 4, 2019
1,923
8,510
North East Riviera
Low profile
Enough to Survive
The fridge will have two 12v power feeds.....the main supply and a smaller cable (d+) which is a 12v signal so the fridge will operate only with the engine running, check the fuse for this feed.
It could be shown on the fuse box as two squares joined together.....mine is like the three amp one on the right as it also supplies the simulated engine running signal to my split charge relay, hence looking like two battteries linked)
Yours could be different or inline somewhere.
Helen Ariel
Aug 20, 2019
1,727
12,097
Dethleffs Pulse
It could be shown on the fuse box as two squares joined together.....mine is like the three amp one on the right.
Thanks we'll have a look at the fuse box when we get to Lagos. Clueless newbies here.
  • HeartHug
Reactions: HKF
Jan 23, 2016
1,921
309,112
Wales
Adria Coral 660SP
25 years
When my fridge stopped working on 12v, but good on the other two sources, a small cable from the battery to the electrobloc had failed, that in itself stopped the fridge working but the short caused a failure in the electrobloc so that needed some refurbishment.
Jan 2, 2015
2,476
8,646
Cumbria
Burstner Solano t725
since 2014
We had the starter battery replaced in Spain a couple of years ago. When we left the workshop, the fridge wouldn't work on 12v whist driving.
Eventually worked out that there was a 20A fuse on the +ve terminal of the starter battery and the fitter had dislodged it. Refitted fuse, problem fixed.
Burstner based on a 2010 Fiat Ducato. Starter battery under floor by passenger footwell RHD.
Good Luck
Helen Ariel
Aug 20, 2019
1,727
12,097
Dethleffs Pulse
Best pic I can get. Model is the Schaudt Elektroblock EBL102.
BuilderBob
74
188
nn297tl
E745 Bessacar
12yrs
I think the electric element is a prime suspect, they are a very common failiure in a domestic setting
A test meter across the element terminals will confirm, closed circuit ok, open circuit, element failed, quick and easy without dismantling anything.
Apr 27, 2016
6,932
8,096
Manchester
A class Hymer
Since the 80s
On the EBL102, the fuse for the 12V power to the fridge 12V element is not quite in the picture. There are two fuses just to the left. If it helps, 'Internes Lademodul' is the Internal Charger Module, and 'Kuhlschrank' is the Fridge. It's a 20A fuse.
There is another 20A fuse, as namwaldog says, near the starter battery. There's a main fuse, probably 50A, and next to it is the 20A fuse. There may also be a third fuse, 2A, in that location.
Jul 20, 2018
440
1,233
Bridport Dorset
Swift Kontiki 655
Trailer tent for 10 years Motorhome since 2018
Hi, had similar issue all fuses ok from engine compartment back to fridge relay behind external vent area. Also fuses in domestic fuse / MCB consumer unit. Turned out to be changeover relay in engine compartment not sending power when required.
43,423
50,187
An hours drive to get more gas is neither here nor there.... The fridge will stay cold far longer than that if the door isn't opened.
Sort the 12v later when you have gas again.
Helen Ariel
Aug 20, 2019
1,727
12,097
Dethleffs Pulse
Yes but we need to get it working again for when we do do longer trips. Just discovered it wasn't working because we ran out of gas and had expected the 12v to take over on the drive.
Helen Ariel
Aug 20, 2019
1,727
12,097
Dethleffs Pulse
It hasn't stopped raining or blowing a gale since speaking to Lenny HB on the phone so we are yet to get the multimeter on the circuit to check resistance. Hopefully tomorrow. All fuses removed and checked seem fine.
Apr 27, 2016
6,932
8,096
Manchester
A class Hymer
Since the 80s
When you get round to checking behind the fridge, it helps to know that there are two separate 12V supplies, and in addition there's the D+ signal.
The 'low power' 12V supply comes from the leisure battery, and runs the fridge control board. It's more or less permanently on, even if you switch the 12V habitation off on the display panel. It must be working OK, because the gas and mains wouldn't work without it.
The 'high power' 12V supply comes from the starter battery/alternator, and only feeds the 12V fridge heater element. There's a 20A fuse on the EBL and a 20A fuse near the starter battery, as described previously.
The D+ signal is a wire from the alternator that is 0V when the engine is stopped, and jumps to +12V when the engine has finished the startup procedure and the alternator is running properly. It is used generally as a signal that the engine is running. The D+ signal goes to the EBL, and switches various relays like the split charge relay and the supply for the 12V element of the fridge. Also, it goes to the fridge control board, and is used by the Automatic Energy Selector (AES) to decide what power source to use (mains, gas, 12V).
So you can see that there are lots of places where it could go wrong.
Jan 28, 2008
10,137
18,421
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
you need to diss one terminal or you could get a circuit back to the electrobloc
Helen Ariel
Aug 20, 2019
1,727
12,097
Dethleffs Pulse
Will get some pictures tomorrow when we attempt this. Thanks all.
Aug 7, 2020
182
177
Carado T339
Hi Helen, had similar problems on my 4year Thetford fridge. Had to replace the control panel on the fridge itself after exhausting all the fuse issues. Fairly easy to replace and get one...though about £100 :frowny:
Helen Ariel
Aug 20, 2019
1,727
12,097
Dethleffs Pulse
Ok, here’s the pics from the back of the fridge;
Engine running gives 14.38v
Engine off gives 13.28v, not sure why pic is upside down!
Split the connector with the 12v feed and it measures 1 on the 2000 scale of resistance.
Cover off but I can’t work out which is the D+ feed as the only wiring diagram I can find is a bit vague...
Thanks for the help so far!
Helen Ariel
Aug 20, 2019
1,727
12,097
Dethleffs Pulse
Ok, found the other two fuses. Both seem ok.
Also found a 40a, 10a and 2a by the leisure batteries under the drivers seat. If you pull the 2a it switches the whole 12v system off so it’s fine.
Will check for the starter battery by the passenger seat as mentioned by namwaldog
Cheers!
Apr 27, 2016
6,932
8,096
Manchester
A class Hymer
Since the 80s
The low-power supply is the violet (pos) and black (neg) thin wires on that connector you were probing. It should be on all the time.
I can't find a definite diagram showing the D+, but by elimination it's most likely to be the orange wire. You could try that (probe between orange D+ and the black negative wire) with the engine running/stopped to see if it changes.
The 1 ohm reading looks OK to me. It's not very accurate (more than 0.5 but less than 1.5) but if there was a fault it would read 0 or OVLD (very high resistance). For slightly better accuracy you could try on the 200 range. Before you measure, touch the probes together to measure the probe lead resistance, and subtract it from the element reading. I'd expect about 1.4 for a 100 watt element, 0.7 for a 200 watt element.
For example, if touching the probes shows 0.3 ohms, and the element reading is 1.0 ohms, then the true element resistance is 0.7 ohms.
Fat ale
Hymer 650
Have you checked the EARTH on the fridge itself ?
Nov 20, 2017
491
640
Worcestershire
Dethleffs
Morning I am fairly sure the D+ wire is the orange wire ,if you search Thetford AES fridge wiring diagram you will find Thetford fridge installation drop down menu where you can choose your particular appliance , it will include the appropriate wiring diagram which hopefully will help ! Good Luck
Wikky
342
664
Cambridge
Rapido 7065+
Since 2003
I have to turn mine off and on again to get it to work on another energy source.
