Kai Morrison
Thanks bigalw35 I’ll take a look at that ??Try “Bondic” glue, uv activated, comes with its own small uv lamp, but do the repair inside the house as the sunlight also activates bondic
That's a good point, at ten years old the plastic may be getting brittle especially when it's cold. I suggest waiting until it gets warmer although you could try a hair dryer.steve69....go easy removing the fridge vents.....I had a go at taking one off my moho this week (just to to take a nosey behind) and despite doing it correctly without being heavy handed, managed to snap it in the corner....thats £90 for a replacement then.
you filling it from streams? ours is inside and spotless we just drain it if were not using for more than a couple of weeksI wouldn't drink out of a ten year old tank. Our van is 5 years old, I clean the tank properly (I thought) every year and it looks like this inside... ???
No ? only chlorinated tap water and clean it with VWP powder which is the same as puri clean. I'll have to mix it up stronger. It's difficult to get in physically to scrub it. This is the top, with a 100mil screw cap.you filling it from streams? ours is inside and spotless we just drain it if were not using for more than a couple of weeks
It has a drain valve?, but it doesn't look like it drains all the water out. ?It would appear that we’re luckier than you, I also clean out our internal tank after each away, ours is spotless, like new, plus ours has a drain plug, does yours not have a plug ?
Tyres are meant to be replaced after five years as the material degrades meaning you can have very little wear but they are more than likely to fail. I know, I have had that happened to me more than once so never again.1 - can you post some photos?
2 - I think they need replacing - I believe 6 years is the safety limit
3 - no idea!
Oops wrong post
Actually ? that's an idea for todays task ? there is a cheap filter on the pump outlet but I can remove the tank and thoroughly clean it ?Ours doesn’t empty completely, so I put an old towel in to soak up the remaining water, then wipe it dry, so it’s always clean, I’ve also installed an inline water filter
