22mm suspension nuts
Or is it 5/8th? :LOL:
Except you lose strength because the pitch angle is different. :)
Anyway I think, having used all the others mentioned, that Metric is simple and easily described when buying replacements.
The problem I had was two rounded nuts on the U bolts. I ordered a 22mm nut removal kit
it did the job well, after filing flats on the two nuts proved to be the answer for me, tightened
back up to 110 mn with no problem. Thank you so much for all the help and advice from all of
you. This has made such a difference to know you are all out there, thanks once again. The only
thing is to lower the M/H off the axle stands. and enjoy the rides.
Kind Regards Mike (Vana)
