2021 Fiat Ducato DPF Sensor Location (1 Viewer)
Nov 17, 2023
16
11
Adria Compact SC
My amber check engine light and engine start/stop disabled light have been on since the start of a 2,500 mile trip around Scotland. I'm home now and it remains on and I need to get the van it's first MOT so I plan on replacing the DPF sensor to see if that fixes the issue. I've had a good look under the van but cannot see it. Can anyone help me find it. I did spot a sensor on the bulkhead, but I don't think it's the DPF, but I've added some photo's of it just to confirm.
Dec 12, 2010
5,446
21,837
Cumbria
since 2011
What makes you think it's the DPF sensor, have you had the fault codes read ?
May 30, 2019
717
1,031
Aberdeen, UK
Adria Twin Supreme
Since 2018
I had exactly the same on Monday, but in Burgundy in France.
Went to a Fiat Prof garage and a combination of waving, my very bad French and his bad English got the diagnostic hooked up. He said it was safe to travel home. 50 miles up the road engine management light went out.
I believe it’s partly because I tend to drive in France on eco, the gear ratios match much better at 30, 50 and 80 km for a more comfortable drive. As the revs have been low the cat has not been able to regen.
If yours is an auto try putting it in power mode and run for 25 miles or so, if manual run in high gear to keep the revs up. It’ll probably clear it. As it’s an orange light it’s doubtful you’ll do any damage.
BTW the sensor you want is attached to the exhaust system behind the front wheel.
Learning points for me is give it a blast every now and then and when I get home get a code reader so I know what the orange light means.
Any good code readers which match iPad?
Oct 6, 2021
569
911
PVC
View attachment 892493 View attachment 892495View attachment 892497
How many miles had your van done before the Scotland trip. If its around 2000, then its almost certainly the nox sensor. As has been said its a known issue with 2021 vans, and invariable puts the engine management light on after 2000 miles. I suspect this sensor is disabled when the engine is new.
Jan 27, 2018
2,698
2,152
Northampton
Rapido & Bongone
the Differential DPF sensor is low down on an X250 but in an X290 is precisly the location you indicate. Have you got any test equipment preferably a scanner such as Multiecuscan or Alfaobd if not a multimeter will do if you can backprobe the sensor and check the 5v earth and signal wire.
Differential Pressure Sensor signal is measured in mV.
an example of Pressure versus mV
Anything between .5 and 2V is OK a working device. Blow out the pipes to ensure no water blockage.
As previously been said Proper diagnosis is preferable to parts canon.
The Differential DPF sensor must be read to the ecu to reset parameters held in the ecu. Not possible with cheap devices but can with Multiecuscan or Alfaobd.
