2008 S-liner 700 glass hob (1 Viewer)
Jan 11, 2014
96
41
Medway, Kent
Since 2011
The glass hob on my cooker has cracked and needs replacing. Its a Dynaxo 2 hob unit. Have inquired from Germany and a new unit is around £800. Has anyone changed one for a more conventional gas hob and if so how?
TheBig1
17,641
43,445
a piece of smoke grey acrylic could be fitted
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
Is there not a glazing manufacturer who could make you one?
TheBig1
17,641
43,445
a sheet of glass could be cut, drilled, polished and hardened, however for what it does, using fragile glass seems ridiculous. a piece of 6mm acrylic would do the same job, look the same but not break again
smithy184
Jan 11, 2014
96
41
Medway, Kent
Since 2011
Should have explained the hob in more detail. It is more like a ceramic hob but with a flat glass surface that the pans sit on over the gas burners. Have seen photo's of similar knaus models that have had a proper gas hob fitted and was hoping that a funster had done something similar.
TheBig1
17,641
43,445
a ridiculous hob to fit in a motorhome. i am certain a conventional hob could be fitted in it's place cheaper
