2006 model fiat problems ?? (1 Viewer)
joggerman
139
6
Lancashire
Just Looking
Since 2004
I am due to collect a March 2007 (2006 model) fiat based motorhome next week
(2 Ltr JTD) from the dealer - 22k miles.
However, I noticed some posts which say that 2006 fiats onwards have "wrong gear ratios and other problems".
As the motorhome in qestion is a 2006 model, would it fall into this range of problem fiats?
If so what problems and with what results?
Should I worry?
Help please before I commit to this van.....
Kon tiki
487
North Wales
Low Line
Do a search for Fiat judder or juddergate, this has been discussed on many forums.
I wouldn't certainly have a good test drive, especially reversing up a slope for a reasonable length. As said it affects the new shape Fiat if it is an older model such as the 2.8 JTD which it possibly is this doesn't have the same problem.
J
joggerman
139
6
Lancashire
Just Looking
Since 2004
It's not the new shape. 1st Reg'd Mar 2nd 2007 (must be 2006 model)
Does this mean I don't need to worry?
I am still interested in any problems the older model has?
hilldweller
605
36,110
Macclesfield
Zilch Mk1
From Aug 2007
You seem to be a born worrier.
Speedo drive nylon gear failure caused by water in gearbox oil. It seems a water drain can drip into a gearbox vent underneath and this can lead to the gear failing. A couple of pounds gear with a few hundred fitting cost. Just get the gearbox oil checked. Mine was OK and they bent the drain further away from the vent.
And stop worrying, it's a very sound motor.
