2 x different AH AGM batteries (1 Viewer)
Nov 2, 2022
153
164
Thaxted, Dunmow, UK
Autocruise Starfire
Newbie
May i ask for advice please. I have an AGM battery (Varta Stop/Start) from my car (surplus to requirements) that is 68AH. I currently have a single 110AH AGM battery in my MH as the Hab battery which works fine. Can I connect them together in Parallel to increase AH output without issue? Thanks in advance.
SteveandSueJ
Nov 2, 2022
153
164
Thaxted, Dunmow, UK
Autocruise Starfire
Newbie
I have read up on various forums and get mixed replies. Some say as long as noth are the same chemistry (AGM) then fine if in parallel. I am not sure, so keen to hear from anyone who definitively knows or who has done/doing this. Thanks...
Apr 6, 2019
3,740
7,451
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
When linked the charger 'sees' one big battery. But personally I wouldn't do it as my little brain doesn't understand how the bigger AH battery gets fully charged without pushing too much to the smaller one.
Aug 15, 2022
62
167
Bristol, UK
Bailey Autograph
1 year and a bit
Both would act as if one, electrically it will be just one battery.
Problem here is the starter battery is not designed to be a leisure battery, the starter battery is designed to give a lot of current for a short space of time (starting the engine) and a leisure battery is designed to give lower current for a longer period of time (lights on, watching tv etc)
Your starter battery would drain the life out of the leisure battery as they are not matched.
If you want two leisure batteries to double your available power buy two new ones, an old one and a new one will knacker the new one.
Hope that makes sense :giggle:
43,334
49,533
The little one sees full charge before the big one which absorbs the remaining charge.
the batteries will only take what they need.
Imagine a 1ltr bowl inside of which is a 500ml bowl.
With a 1.5ltr jug start filling both bowls equally and when the small one is full it will overflow filling the large bowl to capacity.
SteveandSueJ
Nov 2, 2022
153
164
Thaxted, Dunmow, UK
Autocruise Starfire
Newbie
Sounds as though you believe my suggestion is viable, to use both in parallel??
43,334
49,533
Yep.....depending on age though.
Batteries lose capacity with age so that 110ah could be 90ah today so recommended they are similar age to get the true capacity but they will work regardless
Apr 27, 2016
6,875
8,001
Manchester
A class Hymer
Since the 80s
I think it's worth a try to see if the two batteries work together OK when connected in parallel. But if it doesn't work too well, there are alternatives.
Even if you had two completely different batteries, say an AGM and a lithium, you could still use both. You could have a changeover switch that switched the habitation electrics between the two batteries. For charging you could have two mains chargers, one for each battery. Easier than switching the charging profile every time you switch batteries.
SteveandSueJ
Nov 2, 2022
153
164
Thaxted, Dunmow, UK
Autocruise Starfire
Newbie
Good plan, thank you...
Oct 12, 2009
10,676
23,676
A Class N+B Arto 69GL
Since 2009
OR Just carry the starter battery, not connected, as a back-up if the main battery gets low or fails, with a switch to connect it if needed. Switch to the spare occasionally to keep it charged.
I am thinking of putting in a LiFePo4 and keeping an existing L/A as a back-p.
This is the cheapskate solution. :giggle: :LOL:
6,875
8,001
Manchester
A class Hymer
Since the 80s
That's known as a hybrid solution, and is a definite possibility. You may find this thread of interest:
SteveandSueJ
Nov 2, 2022
153
164
Thaxted, Dunmow, UK
Autocruise Starfire
Newbie
Thank you... I think the idea of the 2nd battery in parallel but on a switch, to enable when needed seems a good plan. Switching equally allows controlled charging.. lots to consider....
Dec 31, 2021
511
440
Adria matrix supreme
Is that the same with lithium , we are getting a new van in june which comes with a 100ah lithium, I will have 2 x 100 lithium from the old van , 100ah each and 18months old, could I wire them all in parallel to give a 300ah total?
Mar 23, 2012
9,551
32,141
sleights
c class
I think if it was me I'd use the 18 month old ones that you know work together and sell the new one as I don't know about the compatibility of different makes of lithium with different BMS. It would however make any warranty issues " interesting" and you would need to make sure the B2B are charger are up to it
SteveandSueJ
Nov 2, 2022
153
164
Thaxted, Dunmow, UK
Autocruise Starfire
Newbie
Good question. From what I got back from my question, only issue might be age and condition of batteries in case of degradation. At least yours are all of the same ampage. I would mix yours in parallel, not mine as differing ampage. The experts will be along soon I suspect.
Dec 31, 2021
511
440
I am trying to understand the b2b , we are fairly light users, around 30ah per night if off grid. How is the b2b affected if the recharge required is to 1 battery or spread over 3? As it's still 30ah required?
Mar 23, 2012
9,551
32,141
sleights
c class
I'm no expert but the amount of charge required will be the same the charging rate would differ. I think you need to ask the dealer your new MH is coming from.
Feb 14, 2021
3,625
7,801
Milton Keynes, UK
Burstner Lyseo 727G
19 month year 18000 miles UK, Ireland, France, Spain, Germany, Italy. Campsites and off Grid.
It will take longer. It has been suggested that chargers can break because they are not designed to be charging as long as that. 3 batteries will work the charger a lot harder.
Apr 27, 2016
6,875
8,001
Manchester
A class Hymer
Since the 80s
A B2B works as a 3-stage charger, taking power from the alternator at whatever voltage it pushes out (12V, 15V, whatever) and changing it into the voltage and amps that the battery needs.
Typically, in the first stage it pushes out its full amps output, while constantly monitoring the voltage as it slowly rises to see if it has reached the target voltage. If there are three batteries, all in about the same state of charge, the amps will be divided about equally between them. If one of them is for some reason in a lower state of charge, it will get more of the amps than the others, but the total will remain the same.
If you want to put back 30Ah that you took from the day before, then a 30A B2B would take about 1 hour to do this, in theory. In practice, it would work at 30A for about 50 minutes, until it put 80% of the charge back, then dial back the amps at a constant voltage until the amps fell to about 3A, which might take 30 minutes or so. It would make no difference whether there was one battery or ten batteries, it would still be putting 30Ah back.
