1999 Roadster 630 12v issue? (1 Viewer)
Jonmgoo
3
Lunar Roadster 630
I'm a newbie
Hi guys, just got my first MH, it's a Lunar Roadster 630 1999 model year ??. Is there a switch to flick over to 12v? Thanks in advance John.
Hymie
810
1,005
Essex
Classic Hymer B564
Since 1981
Should be a red isolator switch somewhere, usually near the 12v fuse box.
J
Jonmgoo
3
Lunar Roadster 630
I'm a newbie
Thanks for the replies guys. The leisure battery is fully charged as I checked it with a multimeter, there is some sort of control panel as you go through the door but nothing on it that denotes 12v? I just recently got the MH & still finding my way around it so it's all a mystery & adventure at the minute ?. Would you expect there to be a switch of some kind?
SteveJ
329
526
March, Cambridgeshire
Lunar Roadstar 620
Since 2013
Most of the electrics on our 1999 Roadstar 620 are under the rear lounge seat, drivers side, but as your control panel is near your hab door it sound a bit different to our 620. There is a couple of fuses in our control panel as well as a set of trips under the bench seat. I'll go and take a quick look at the controls on mine as I can't remember what I had to do last time I shut the 12V off to wire in some USB sockets. Do you have the manual? If not I have attached the wiring diagram from my manual, which should be fairly similar. Let me know if you need the full manual.
  • roadstar_wiring.zip
43,334
49,531
Is there a 3 position rocker switch on the panel with a pictogram of a cab and living area at top and bottom and nothing in middle position.
If so switch it to living area.
SteveJ
329
526
Lunar Roadstar 620
Since 2013
As pappajohn just said. Just double checked on mine, if you have the same control panel then the middle rocker switch switches between the Starter (up) and Leisure (down) batteries, middle is 12V turned off.
