Fuses all look goodHave you found any fuses?
If i turn ignition on have 12v sockets in cab work ok, the one by tv aerial still nothing.Need more detail?
Have you measured voltage at the socket?
Have you got 12V everywhere else - lights, other sockets, roof fans etc?
You need a tester to sure.Fuses all look good
I was just about to suggest this.Do you have an "aux" switch on your control panel? This may need to be on for the 12v socket to work
Fuses need checking with a meter for continuity as a visual check just isn't reliable enough.Fuses all look good
What kind of sockets are they?I've buzzed out all fuses and all are good.
It's a cigarette lighter type socket.What kind of sockets are they?
Have you taken the backs of all of the sockets in the van?
Are they all the same coloured wiring?
It's the only 12v socket in the living area, so I think it's not a optional extra.I know nothing about Auto Trail but some manufacturers fit wiring for options but do not connect it unless the option is selected when ordering new. Is this socket there for an optional second tv in the bedroom? If so perhaps it has not been fully connected. As I say I know nothing about your particular motorhome, just guessing based on what some other manufacturers do.
If there is power at the fuse then you can only try and trace the two wires down the van.Its a c
There is only one in the living area.
The one in the xab works when the ignition is on.
Hi, there is 12v power to lights, pump, etc.There seems to be a few reasons why it isnt working
no power -
blown/faulty fuse which youve checked to be ok
wiring disconnected or damaged or additional in line fuse that you havent located is faulty - can you do some sort of continuity test on both wires (you may need to have some spare cable to lengthen the cables to test them? - it might be the lack of a properly connected earth or live ? is there a switch to isolate that particular socket that you havent found?
faulty fitting -
can you remove the fitting and connect up something else that operates on 12v? are the connections faulty/loose?
have you tried testing with the ignition on aswell as off?
my experience in these issues (some of which i have created myself) is that you need to methodically go through the process of testing and checking from one end of the 'circuit' to the other. often time consuming
Try reducing the size of the photo first, large images often stall on slow connections.How do I upload a photo?
Try on here to show part of circuit diagram from manual and it gets to 88% then stops.
