That oblong thing looks like 2 relays taped together, and they've been getting hot.
Thank you. Just looked again and yes it is taped over .going to get new relays but can’t see any numbersThat oblong thing looks like 2 relays taped together, and they've been getting hot.
Disconnect them and take that tape off then inspect them, I'd also cut all of those crimps off and replacing them with new ones. They've probably started to melt because the connections are corroded.Thank you. Just looked again and yes it is taped over .going to get new relays but can’t see any numbers
Mines got 12v 30 amp stamped on it . Will it be ok to go higherWhile fixing your problems and redoing the wire terminals, if it was my MH I'd take the opportunity to upgrade a bit.
That split charge relay is not really up to the job. Standard spade terminals (6.3mm) are OK for 15A, but are near their limit at 20A. A split charge relay would I guess take 30 or 40 amps, maybe only briefly, but if the leisure battery is quite low it might be sustained for some time. To be honest, that split charge relay looks like I would expect a 30A relay to look after some years of duty.
I would go for a 70A relay, with a socket. The power terminals are bigger, 9.5mm, so will take the amps easily. The coil terminals to trigger the relay don't take much current, so the standard terminals are fine for those.
If you go for a new fridge relay, a standard 40A will be fine. You could get a socket for that too, and the two sockets would slide together so could be fixed as one piece - no more tape required.
While you are changing things, it's worth looking at the wire from the starter battery. This really should have a fuse at the starter battery end. An inline fuse like that Maxi fuse would be OK. You don't have to put in a new wire, but if you do, make it a bit thicker.
If the Maxi fuse is quite large (maybe 50A) then a smaller fuse on the wire to the fridge relay would be a good idea. an inline standard fuse, 20A, would be OK. If you're buying a new fridge relay, you could get one with a built-in fuse holder.
Relay 12vdc 70 Amp switching current 4 pin. ALT/RY268763-1-09
ALT/RY268763-1-09 Pack sizes 1, 10, 50, 100 200 70 Amp switching 4 pin 12 volt DC relay unit. 2 x 9.5mm male terminals (switching contacts) 2 xwww.altecautomotive.co.uk
Relay base / holder for 70 Amp 4 pin relay ALT/RELH005B-1-09
ALT/RELH005B-1-09 Single 4 pin relay base / holder suitable for our 70 Amp 4 pin relay. (We also offer a 5 Pin relay base suitable for our 70A 5 pinwww.altecautomotive.co.uk
4 Pin automotive type 12 volt 40Amp relay ALT/RY1-1-02
ALT/RY1-1-02 4 Pin automotive type 12 volt 40Amp relay 4 pin 12 volt N/O (Normally Open) 40 Amp relay. Connections are madewww.altecautomotive.co.uk
PROFESSIONAL QUALITY Automotive relay holder ALT/RELH45B-NT-1-09<br>
ALT/RELH45B-NT-1-09 PROFESSIONAL QUALITY ***Terminals supplied separately*** Bulk packages available 1, 10, 100 500 (Item with terminals basewww.altecautomotive.co.uk
The 30A is a maximum limit that the relay will carry without long-term effects. I'd imagine the charging current is often at 30A, or maybe a bit more. A 40A would be better than 30A. A lot of people use 70A for split charge relays, so a 30 or 40A current would be comfortably within its 70A range.Mines got 12v 30 amp stamped on it . Will it be ok to go higher
It’s a 1995 boxer with a holdsworth conversion. Think I may have to live without the 12 volt
