Sounds vaguely familiar.......There isn't one, we have tried loads over the years as my wife simply will not go away in the camper unless she has a hair dryer
Ha! Ditto. All those who say just let it dry naturally have NO idea.Before we were set up to use my proper hairdryer and ghd’s we just used to go on a site and have hook up.
As I only wash it once a week it’s no big deal . Though that would be if you need to do it everyday .
As for drying hair using vents .
I suppose that’s ok If you have short / thin hair. But if you have thick styled hair , nope, it won’t do.
I’d look like
The only time you'll get any decent heat from 12v is when the melting 12v wiring sets fire to the van.
For us the solution was a big pure sine wave inverter!
Dyson hairdryer works well on a 1500 w inverter, with either the heat or blow tuned down one stop from full power
Are you saying that nobody uses inverters?The power from the inverter is coming out of the 12v batteries, so it's not a battery problem.
You could make a 1200 watt 12 volt hairdryer, but it would take 1200/12 = 100 amps. It would need wires like heavy-duty jump leads, about the same size as water hose. And it would need one of those big Anderson connectors used for golf cart batteries. Nobody would buy it.
12 volts = 12 watts per amp.
240 volts = 240 watts per amp.
NO he is saying that a 12v hair dryer is not limited by the batteries BUT by the cable and connectors, the fact that so many people run hair dryers off inverters is the proof that the batteries are capable.Are you saying that nobody uses inverters?
Not every one has payload or storage issues so my large pure sine wave inverter handles 10 - 15minutes hairdryer use without any issue what so ever
I bought my wife a 12v one when we got the MOHO and she turned it on for 5 seconds and then switched it off and said I’ll air dry it.
Useless
There is a minimum 10 fold difference in power requirement. Hair straighteners & heated brushes are rated around 40-50W. Blown air hair dryers are a minimum of 10 times that & usually 20 times.I wonder why no one has invented a gas hair drier like the straighteners?
Surely you would only be heating an element and have a small 12v fan to blow the heat. A rechargeable battery would take care of the fan.
Bet they would sell like hot cakes
