Swifter
Firstly please no digs about Swift of British built vans please . Not in the best of moods after today.
Basically I gave the motorhome the first wash of the year today and also a good walk round and check over . Spotted a nasty gap in the sealant between the body trim and the side wall under the cassette access hatch . I was aware of a problem with the trim allowing water to get behind it and cause the floor to get wet underneath the van .
I had just washed it so I had I look underneath and this is what it looked like .
I pressed the floor from underneath and sure enough it was spongy
. I’ve had a good search on here and it appears it been a big problem with others in the past . I think I may have caught it early but the damage isn’t good .
The problem is a black sheet of vinyl attached to the timber .Water runs down the van and behind the trim . The floor soaks in the water and the vinyl prevents the timber from ever drying out .
Checked the whole underside and there is a patch the other side under the step as well![See-no-evil monkey :see_no_evil: 🙈](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f648.png)
I’ve removed the offending vinyl to see the damage . It’s bad but the inside of the van is dry and it’s just the bottom layer of ply timber that’s wet . I hope to cut out the board and replace it . Not very good at this kind of thing but will give it a go .
pictures of the vinyl cover that traps the water and the damage .
![Slightly frowning face :slight_frown: 🙁](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
