Don't kick ya self for buying a part duff one, you've sorted it cheaply. Half full budI wouldn’t worry about it in your case . It’s the plastic cover that caused all the problems as the wood that was getting wet from the unsealed side trim was unable to ever dry out and was completely sealed in when damp . Thank god I found the problem when I did because it was never ever going to dry out . I am disappointed with myself for buying a motorhome that had these problems but I will also never make the same mistake again . If you think the underside of the motorhome needs a paint then just sand back a little and then paint it. It’s not a very quick process as you will be on your back with most of the paint trying fall off the brush so it takes a while . Luckily I was able to paint the replacement boards before fixing them in place . I only needed to paint a few of the underside areas directly so it wasn’t a long process .![]()
I had heard about Swift replacing the floors on older vans but also heard that started to refuse from about 2014 onwards . I would imagine that even if they did agree to carry out the work on this now 15 year old motorhome it would be away for several months . May I ask what year they did the work for you ?Ours was a 2005 Swift and had the same problem. Swift accepted that it was a design fault and replaced the floor free even though it was out of waranty.
Someione we know went to collect his from the factory after repair and there were 20 of the same year waiting to be done.
They collected it and returned it to us although they wanted us to go to their factory. We refused.
If you want to go this way don't let them pur you off.
They know all about it but I expect you'd have to be strong with them about it to get it fixed.
How did you get on at Cannock Resprays ?Different vehicle I know. I have a patch of rot in my floor, behind one of the rear wheels.
I could repair it myself but i'm taking it to Cannock Resprays , post April 12th.
If their quote is not too shocking they will do it , they have an excellent reputation.
Just metioning it in case you might want a quote.
Also Dave Newell in Telford perhaps , noting you are near Hereford.
If doing it myself I had planned to cut the floor out using a plunge tool, epoxy the edge , fix a marine ply section back in and marine ply the outside surface with a thinner section to give it strength and seal off the repair. All done with wicked adhesives and epoxy. I can (just) get to the inside surface.
Mine is similar I guess , outer ply, then foam insulation, then ply then inside floor covering.
Total thickness about 1.5"
They have quoted now , it was eye watering.How did you get on at Cannock Resprays ?
