Zehnder dx 75e (2 Viewers)
ShiftZZ
21,386
84,827
Dark Side of the Moon
Just installed one and it works fine, besides, when setting up the sat channels,one of the menu buttons turns off the TV, any suggestions? NO, not the red on/off one :Doh:
43,384
49,810
exactly the same problem !
it must be on the very same frequency as the tv off button.
i just avoid that button.
I also found increasing the Zehnders volume decreases the tv's volume but not the other way round.
i set the volume on the Zehnder then use the tv remote to increase/decrease the volume
ShiftZZ
ShiftZZ
21,386
84,827
Got a reply from Germany..
"Dear Mr.Shift,
that means that both RCUs have similar coding. You can do nothing except you cover the IR-window of your TV-set, so that RCU signals cannot be reached by TV set. From now on switch on/Off your TV set manually.
Best regards.
Corsin Kleiner
Product Manager
mailto: kleiner@zehnder-sat.de
Phone: +49 7729 881-37
FAX: +49 7729 881-77"
Technology at its worst,.
