X250 2011 Document holder help needed (2 Viewers)
SandJ
1,799
818
North Yorks
Too long lol
Can anyone advise if the following is correct and any solutions as to a remedy?
TIA
If I remove the document compartment from above radio see fig
Can I then remove (rigid, not adjustable as older models) map holder with clip by removing two screws from locations as per fig , is there only the two screws?
Can the clip then be repaired or is it a full replacement? The reason being the clip has come away and only the spring remains.
If full part needed does anyone know part no or location of part?
Thanks again for help
Dec 6, 2011
11,611
25,496
South Wales
Coach built Adria
its a simple job of pull out the compartment and 2 x screws ( dont drop any ) :whistle:... been there..:).
lift the front and it lifts out. there are 2 types of clip board one that raises and one that does not as far as i am aware you cannot get at the mechanism in the back of the clip board to repair. but its such a simple job to get it off its worth checking.
SandJ
SandJ
1,799
818
North Yorks
Too long lol
:clap:
Thank Phill looks like I will have to source a replacement one (fixed type)
Tried to find on eBay but failed so far
Dec 6, 2011
11,611
25,496
South Wales
Coach built Adria
as its under the dash and cant be seen it may be worth doing a bit of hacking on the inside to see if you can get it fixed and super glue it back. nothing to loose if you are going to buy new (y)
SandJ
SandJ
1,799
818
North Yorks
Too long lol
Will have a look when I get if off Phill buggered if I can find its correct part name but will have to go to dealers if it can't be repaired. Lol the last time I put a fix for a fridge lock on here I basically got called a cheapskate. The fix works better than the original lol thanks again Phill
Puddleduck
12,387
44,009
Scottish Borders
Without at present
On and off for many years.
Modern society is far to ready to throw away things that can be easily and cheaply repaired. If it is just the spring clip that is broken could you get another from a Poundland clip board and replace it with that? Probably not but just a thought.
SandJ
SandJ
1,799
818
North Yorks
Too long lol
I agree with you
It is Not the spring itself but the clasps that hold the clip onto a rod it seems that the clip and spring slip onto rod but the plastic bits on clip have broken it is in storage or would post a pic. I am in no rush as it's not vital and I am asking for ideas in case anyone else has had the same problem.
Jul 31, 2014
1,930
3,241
West Yorkshire
EuraMobil Activa 820HS
Just come across your post - I know it's an old one, but just seen this part advertised on eBay 121491304333
Not sure if it's correct colour though.
