Wiring cbe ds470-ra distribution (1 Viewer)
Jun 25, 2012
266
77
Essex
Low profile
Joined 2014
Does anyone have a wiring diagram I’m trying to work out how to wire a dual solar charger ie hab battery and vehicle battery any help would greatly appreciated
Jan 27, 2018
2,679
2,127
Northampton
Rapido & Bongone
There is more than way to connect to solar
1 Direct from controller to batteries using at least 6mm cable for low voltage losses.
2 Controller hab battery to -B2 +B2 Controller van battery to +B1 (as cbe300 ) depends on quality of van wiring effectively same as 1.
3 is there anything in the manual that indicates that the display gives any useful info on a solar connection , that implies connection 38 OUT could/should be connected to hab lesuire battery and -B2 32. Van +B1
Sorry i couldn't find any helpful info on your module.
Mine is a cbe300 with solar connected as 1 (initially as dealer fitted, micky mouse wiring) rewired with 6mm cable and Votronics controller.
Apr 9, 2014
1,308
6,597
Lincs
Katies-travels , maybe not related but, we have a DS470 box in our Frankia, mains charging is handled by 2 x CB-522 units, engine leisure battery charging is via the DS470 and solar via a CBE PRS300 unit the control panel is a CBE PC380 this does provide details on the solar charging etc...
From your original post do you have manual for the DS470?
Steve and Denise
5,302
14,119
Spalding LINCS
A Class Carthago
Since 2008
Most things about CBE DS470 CS/da/ea are kept a close secret by the manufacturer so no one can repair the crap that they produce with inbuilt faults🤬
