Wireless rear view camera (1 Viewer)
Apr 29, 2014
143
221
isle of man
coachbuilt
since 2011
I am carrying a small motorcycle on the scooter rack at the back of my Eldiss 180 length 7.2m for the first time and I am wanting a to buy a camera for the rear. It would need to operational while we are travelling so too observe the Bike ref security etc. I mention wireless because we are departing on our holidays in 2 weeks time and want something I can install quickly. I have a budget of about £90.00 to spend on the device, is there anyone who can recommend a reliable camera.
Thanks Steve
Aug 14, 2007
526
104
Devizes
Mobilvetta K-Yacht 80
Hi,
A lot of folks have installed this one:
Broken Link Removed
I bought one, tried it and it worked fine, but then I spotted I had a cable built in. Waiting to see if I can get the correct camera for the Rapido. So, mine, unused may be up for sale.
Regards
Chris
3,425
12,320
South Staffs
Pilote P740GJ
Since 2013
Wireless ok if you can't be bothered with e wired one. Just remember it will never be as effective as a wired one.
Dave.
tambo
874
639
Dunfermline fife scotland
a class
MH Since 2008, ex tugger and vw campers since 1992
I can't paste links with this phone but there's a wireless one on ebay has the 7 inch dash monitor and the 18 led night reverse camera in hd for £45
This is a great kit I had one on my last van and my sister has one on hers just now
Does exactly the same as a hardwired camera which I've had fitted on other vans .....
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
wired is always the best option, a little like a land line and a mobile, land line is always guaranteed to have a ringtone, mobile not so if you get the drift ! I remember reading a thread on here about wireless cameras and someone seen a motorhome reverse into something because his wireless camera was picking up a signal from another vehicle ;)
tambo
874
639
a class
Sounds like that robbed when gassed excuse :p
Bad driver blaming his tools :)
These days I use my mirrors no camera
526
104
Devizes
Just to let you know, I am an electronics engineer in the field of communication.
With that said, let me explain. Wireless, if set up properly and using correct or good radio will be as good as any wired system. In fact so good, a lot of people are using it successfully with no ill effect!
The system I linked to above, is, I believe, the one Tambo has mentioned.
I tested it and it worked fine over the 6M of my panel van. Remember, my metal van will have more problems than a fibreglass/plastic motorhome.
There is no guarantee that any low cost radio system will work. Trial and error or money back deals are the only way to go. These systems use very low power radio.
In terms of wiring, all you need to do is pick up 12V. You have a choice and these are some of them.
1. Pick up reversing lights. The camera will only come on when you select reverse
2. Pick up any side light. You would then need to turn on the side lights to turn the camera on.
3. If you have a towbar, pick up the 12V
4. Run a cable under the vehicle bringing 12V from the vehicle fuse box, or direct from the battery with of course a fuse in the line and next to the battery.
All in all, a much easier way of installing a reversing camera. If I had not already got a cable and monitor, I would be happy to install the one I mention above.
Best regards
Chris
benellioldman1
Apr 29, 2014
143
221
isle of man
coachbuilt
since 2011
Ok
thanks for your help I will go for one of the wireless options mentioned above and pick up a 12v supply near to the rear of the van
Cheers Steve
3,425
12,320
South Staffs
Pilote P740GJ
Since 2013
Hi Dave,
Just wondering why you think this?
Best regards
Chris
Hi Chris, I based that on anything I have had wireless has been prone to interference, bike computers, heart rate
monitors. I passed under some low slung high voltage cables once and my heart rate showed 250bpm.
MattR
4,106
39,205
Beds
Panel van
Years
I wired my camera to the rear side lights so the camera comes on when the side lights are turned on. Works well. The camera came from Maplins (around £60) and is ok but seems to be losing colour saturation so it is becoming less easy to determine where pathways and grass etc. start and stop - not impossible but not ideal.
TheBig1
17,644
43,460
i was given a maplin wireless one a while back, so fitted it in the 4x4. works great if you dont switch bluetooth on your phone on. not exactly ideal if you use bluetooth for hands free etc
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Best regards
Chris
Chris you forgot to say, make sure you buy one with at least 50m hollowness(y)
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Bought a wireless one off Ebay 7 years ago & still works perfectly on our Autocruise Starseeker at 6.5M, without any interference.
Clearly not concentrating on his surroundings.
How anyone reverses using only a camera is madness, I always use the mirrors as well.
