Wire for Solar Lights (1 Viewer)
Vanman
1,666
3,920
Runcorn
Roadscout R PVC
March 2017
Hi - I'm trying to extend the wire on some solar lights so that I can put the panel somewhere higher. I tried adding some speaker cable but I suspect it's not 'fine' enough to carry the 1.2v to the lights. Can anyone point me in the right direction for the wire that I need? I looked on Amazon and Screwfix but sometimes you need to use the 'right word'!
Thanks!
Jan 19, 2014
9,395
24,788
Derbyshire
Elddis Accordo 105
since 2014
Speaker cable should be good... unless there are thousands of LEDs šŸ˜Š
Vanman
Vanman
1,666
3,920
Runcorn
Roadscout R PVC
March 2017
Speaker cable should be be OK. I don't know what you mean about 'fine' enough.
The original wire is only a few strands in diameter, the speaker cable (although not much more than door bell wire) is three or four times thicker. It's not working so I'm thinking that the tiny voltage isn't travelling down the thicker cable. The connections are good so I can't think of any other reason it wouldn't be working. šŸ¤·ā€ā™‚ļø
Sep 17, 2017
5,475
10,222
Birmingham, UK
A-Class
Thicker cable will make it easier for the current to flow.
The issue might be that the hair thin wires are coated. It can be a pain to get the coating off to make a connection to them.
Jul 6, 2009
1,801
2,225
Donā€™t forget ledā€™s are polarity conscious??
Jul 3, 2021
30
52
Lincolnshire, UK
Swift Kon-tiki Sport
Still learning Since 2015
You may need to check that you have not crossed the wires over, LEDs have to be wired the right way round. They only work in one direction.
Bessy567 beat me to it and put it more succinctly
Feb 26, 2012
528
368
coach
Motorhome since 2006 (caravanning 38yrs)
Reverse polarity will cook a LED if it hasn't been protected by a diode.
I suggest you check that the 'light' still works with the original connections.
