Windscreen washer bottle.... Help please (2 Viewers)
lesleyjean
1,748
2,392
I am desperately seeking a windscreen washer bottle for my fist ducato 2002 swift Kontiki motorhome.
Having a lot of trouble sourcing one.
Here is a picture of it. Can anyone help please. Ta
movan
21,492
120,753
Moving around
Burstner
since07
Hi Lesley, Very, very long shot but there is a caravan breakers near me who once had a motorhome part I needed for my last van... His phone number is 07746389352. It is probably a no go but miracles do happen as per my motorhome part. If he has one, I can pick it up for you.
old-mo
Extra Special
16,343
93,693
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
If I may be so bold and ask..
What`s up with it... ?
Al-Di
3,063
28,915
prestwich
Eura Mobil A Class
since 2013
just done a quick partsfinder, no luck, its not the standard model,
MattR
4,105
39,123
Beds
Panel van
Years
I wonder if it can be fixed with fiber glass or similar. A body repair kit should do the job from somewhere like Halfrauds.
old-mo
Extra Special
16,343
93,693
Weymouth. Dorset...
It appears to have a hole in the bottom of it.
First picture.
Should've gone to Specsavers. :coolest:
(Other opticians are available) :smiley:
I didn`t see that... :doh:
"Araldite"... and a small patch of Fibre Glass matting will soon fix that..(y)
Just make sure it is clean and oil & grease free... (y)
Fibre glass (Resin & Hardener) will probably separate from the plastic after time.. :(
But Araldite sticks like *hit to a blanket... (y)
lesleyjean
lesleyjean
1,748
2,392
It's got a hole in the bottom:)
I have searched you tube and taken the video to show garage guy of a repair.
Also took another plastic bottle for him to try and plastic weld it.
lesleyjean
lesleyjean
1,748
2,392
Thanks Joy
I did give him a ring, but he didn't have one. :crying:
:Smile:
Apr 9, 2013
663
373
Ayr
Duct tape. Seriously, if the surfaces are clean and dry it'll hold water.
We mended our overturned caravan with duct tape AND completed a two week holiday in it. Never underestimate the power of duct tape. :LOL:
yorkshirepudding
1,220
910
Pudsey/Leeds
Thinking of tenting again
September '09
If it moves when it shouldn't use duct tape. If it doesn't move when it should use WD 40.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
I'd use Sikaflex or silicone.
Clean the bottle round the hole, inside and out. Big dollop of sealant on sticky side of duck tape & fix.
Tape will hold it 'till sealant cures.
MartMaeve
65
43
Just starting out..
Definitely going to try that approach - my washer bottle appears to have sprung a leak along the seam at the bottom middle section, so there should be plenty of opportunity for duct tape to stick whilst the sealant does its thing. I knew I'd find a solution if I looked on here!
Cheers!
M & M
Apr 12, 2012
1,698
6,386
N/E Lincs
Autosleeper Rienza
as above
I have repaired a cooling system header tank with a soldering iron. It was meant to be temporary repair but the new tank was never ordered, it saved money according to my boss.
The electrician wasn’t amused his big soldering iron smelled of plastic for weeks.
Dec 2, 2019
3,610
7,801
Amersham
van conversion
Since 2019
My bike has a modified header, with a bolt thru it for the crush bung. All plastic welded. It’s been holding for years.
Jan 27, 2018
2,678
2,127
Northampton
Rapido & Bongone
My original post was in 2014.
I have sold that vehicle now.
Well what repair method did you use, did it hold?
Real feedback or a cop out " i can't remember "
My favourite would have been standard araldite plus a smig of heat for flow (60C)
Need to be careful with heat and plastics ( thermoplastic or thermosettin)
lesleyjean
lesleyjean
1,748
2,392
The garage managed to source one that fitted. Simples.
