WiFi (1 Viewer)
pvw10
273
45
Gloucester
Coach built
since 2011 after tugging.
Most sites have wifi with secure passwords etc.
Has anybody found a decent repeater booster that i can use on 240 as anything has to be better than my iPhone/ipad ?
Apr 9, 2014
1,308
6,597
Lincs
I like the MotorhomeWifi setup but I'm using the following bits:
  • Alfa R36 802.11 B, G N, Repeater And Range Extender For Awus036H, this work on 12v or 240v just needs the adapter.
  • Alfa AWUS036NHR – High-Gain 2000mw 2W 802.11 B/G/N Wireless USB Network Adaptor
  • although the AWUS036NHR comes with a 5dBi antenna, I also bought a seperate CSL 12dBi rod antenna for wifi, made a big difference
Total cost about 85 pounds. It all works well and lets you setup a wifi connection in and around the van. For me the CSL 12dBi is excellent really made a big difference to the range of the wifi spots I can connect to.
You can plug a Mobile data USB stick in to the R36 instead of the AWUS036NHR , but I found this a right pain and a bit fiddly (config wise) and now use the Netgear Aircard if no Wifi available and want internet access round the van.
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Motorhome wifi iBoost
Or...
Might work
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
If you just want a repeater rather than a 'booster' I have found the Huawei E5336 to be excellent. It latches onto a weak signal far better than my 'smartphone'. You can also insert a SIM for mobile broadband (it is unlocked). I have used it with excellent results in both France and Spain. It has a rechargeable battery so can be placed anywhere inside the motorhome - I have found up in the rooflight is good when the signal is very weak.
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
I'm using the first generation motorhomewifi hub but with my own antenna
The repeater is available in Jims shop
Here at shell island I'm connected to a FON spot a good mile away
Yet again I find myself impressed by your cunning designs. Have you modified an old Status TV aerial or is the pole part of the antenna?
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
