Wifi for numptys (1 Viewer)
highwayman
969
1,033
Herne Bay
Low profile Rapido
Since 2005 ish
Hi folks
I hope someone can help.
Our boys are going to get their own laptops and we're hoping to get and
set-up a wifi system so they can use our broadband connection without
tying-up our computer.
So the questions are,
How do you make the wifi secure?
What's the differance between the expensive and cheap routers?
Will a cheap router service two laptops and a pc at the same time?
Can you keep the explanations simple :wub:
thanks in advance
regards......nige
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Hi, get the fastest router you can afford. Making it secure is fairly easy, there should be instructions with the router. On mine I had to got to a website for my router (Belkin) where there was a "wizard" which was easy to follow. Once you decide which type of security you want and input the number into your computer/laptop you don't have to do this again (unless you want to allow another computer access). ::bigsmile:
Jim
Ringleader
Jul 19, 2007
36,531
131,531
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Hi folks
Almost all routers will have security built in, you may have to turn it on, most routers are controlled via a webpage that they generate, it is really simple to set the passwords.
Range, if you want to use the Wifi in the garden, or have a and cottage with two foot thick stone walls then go for the more powerful ones which are marked "G" or "Pre N" (I think).
Yes, easily.
I've done my best::bigsmile:
thanks in advance
Don't mention it
regards......nige
I am no expert on this stuff, and If I have got anything wrong I am sure that someone will be along sharpish to let you know:roflmto:
GeraldandAnnie
194
137
Essex coast
Since 2006
Hi, Nige
You'll need to make sure the wi-fi router is compatible with your ISP (e.g. AOL and NTL / Virgin might need special versions), and that it has wired connections. They nearly always have these so you can set them up.
I use a Netgear DG834G - you can even buy it from Amazon in the UK. It's very good, and reliable. We often have 2 wired PCs and 3 wireless laptops hung off it. No problems.
