- Dec 24, 2014
- 9,229
- 47,707
- Compass Navigator
- Ever since lighting was by Calor gas.
Yebbut why would you have the wheels turning in opposite directions as each wheel would then need its own individual axle. The actual wheels aren't themselves powered; they are merely slave wheels being turned by the friction of the cables around them. If both wheels shared a common axle the lowering cable could be the one paying out from under one wheel and the lifting cable on the other wheel would be fed at the top of the wheel. Thus with both wheels rotating in the same direction and on a shared axle there would be only one axle and fewer bearings required.Two cages wind from the same drum one up one down ?
That's a point. A gearbox seems an unnecessary complication when it could be eliminated by simply feeding one cable to the top of of one winding wheel and the other cable to bottom of the other wheel as mentioned by Steve and Denise and Landy AndyDon't know but it could be to speed up the load/unload time. One at pit bottom being loaded while the other is pit head being unloaded.
It may be the way the winding drum gearbox works.... A bit like a differential, if jacked up one wheel will turn clockwise, the other anticlockwise. Substitute wheels for drums.
Spriddler your question interested me to the point that I searched on the internet. The answer is surprising - see the cut and paste below:-
So basically, you have one winding wheel per shaft, as there has to be two shafts by law!
Dibnah was a mate of my Dads from teenage years (scrap man) I remember going his place a few times as a kid and meeting him at various steam rallies etc. (pubs and beer tents mostly) me dad said he was tight as cramp.
I think he had a working model in his yard when he got round to finishing it years later (if he did finish it)
He intended to dig a 150' deep shaft but never finished it as the local Council prevented him from digging more than about 10'.
Yes, I did see that clip and website for the Nat'l Mining Museum at Caphouse in my nerdy searches but the two wheels appear to be directly above one mineshaft. Surely they wouldn't have dug a second shaft right next to the first one which would make both shafts at risk of collapsing/subsidence? Plus there' d be little escape advantage if the bottom end of the main and the 'rescue' shafts were adjacent to each other.I think your answer is like steve and denise said, 2 cable runs operating from one drum, 1 up 1 down, makes Physics and cost/engineering sense
BBC - History - British History in depth: Winding Gear Animation
Inside this mechanism of the industrial agewww.bbc.co.uk
Like a v twin engine
Thanks too, to grasscutter and LARRY99 for their added info.
As you will have guessed I'm a bit nerdy about these engineering things and the fascinating history of the first Industrial Revolution (c1740 to 1850) and have spent many weeks visiting the museums and sites in the Black Country and around Ironbridge, plus the Cornish mining areas and historic buildings housing steam powered water and sewage pumping engines and weaving mills.
If anyone with an engineering interest and wants to pass some lockdown time there's a superb but non too techy film on the design and construction of the Iron Bridge here:
And for the engineers and fettlers (O.K. 'Nerds') among us there's another engineering riddle which should be simple to understand but which has taxed my brain. It relates to a surprising (?) feature of ball and roller bearings which I'll put in a separate thread.
(Bet you can't wait!).
