Which battery is which? (1 Viewer)
Jul 16, 2020
22
12
Glenrothes
Talbot Express
since 2018
Can somebody tell me which battery is the van one and which one is the hab one please.
Bobby-gg
1,050
2,379
Northumberland
Ducato IH pvc
Since 2010
Just making a semi educated guess here, but looking at the wires you've left connected it could be the top one, but then again, they are matched batteries, so perhaps they are both your leisure batteries and your starter battery is elsewhere - ducato's have the starter battery under the passenger feet
68c
Oct 22, 2019
1,822
2,804
Southampton
2001 Pilote 270
Since 2004
As they are both disconnected and assuming you can start the engine they are both leisure batteries.
A
Jul 16, 2020
22
12
Glenrothes
Talbot Express
since 2018
These are under the drivers seat. The two batteries are disconnected and the moho doesnt start so one of them is the engine battery.
Lenny HB
53,620
150,700
On the coast in West Sussex
Hymer B678 DL
I also have a 2009 Dethleffs T66 Sunlight which is the moho I am asking the question about.
Justing to confuse us.
If its a Ford they often have two batteries one for engine starting and one for the Ford electrics. Then you would have a seperate leisure battery.
scotjimland
2,380
10,353
A Woosh bang
They are both starting or engine batteries.. not leisure batteries
as Lenny said , suspect your leisure battery is elsewhere
Do you have 12v power in the hab area when these are disconnected.. ?
that will prove it , one way or the other
A
Jul 16, 2020
22
12
Glenrothes
Talbot Express
since 2018
Just been out to check them. The lower battery is the starter battery. There isnt a third battery anywhere as the other battery is the leisure battery as I could operate the internal lights with it on. The starter is the dodgy battery and I bought the same battery to replace it with. Should I go with a different one for the leisure battery.
Apr 9, 2018
8,693
44,981
Worcestershire
Bailey Adamo 75-4t
March 2018
Battery experts will be along, but leisure batteries are usually deep cycle whereas starter batteries are not. Starter batteries are usually capable of higher cranking power.
Lenny HB
53,620
150,700
Hymer B678 DL
Just been out to check them. The lower battery is the starter battery. There isnt a third battery anywhere as the other battery is the leisure battery as I could operate the internal lights with it on. The starter is the dodgy battery and I bought the same battery to replace it with. Should I go with a different one for the leisure batteRY
Starter batteries are not a good choice for leisure batteries, I think your van was originally fitted with a Gel battery. Check the front of your EBL it should have a switch on the right hand side that can switch between lead & Gel as Gel's need a different charging profile.
An 80ah Gel will give you more available power than a 100ah standard lead acid battery
This is probably what was originally fitted.
This is the Sonnenschein equivalent ( they make the Exide Gels ) it says in the listing 75 ah it is actually 78 ah.
43,365
49,701
Or.....cheaper leisure batteries are simply relabeled starter batteries at a premium price.
TheBig1
17,641
43,445
The lower of the 2 batteries is the starter battery. Easy to identify by the wires feeding from it being bigger and the positive having a fuse panel on the terminal. The top one is the leisure
