weights advice? (1 Viewer)
JonVonandDog
18
8
Wellingborough
motorhome
I`m a newbie
Hi Funsters,Need a clarification. The plate in the doorway of our M/H is as follows;
3850 KG
5550 KG
1850 KG
2120 KG
There are no other letters or any guide on these figures.
Apr 29, 2012
312
287
Holmfirth
1990 Gulfstream RV
30yrs
bit strange there are no letters etc. you usually have the unladen weight, the max laden weight, and the then the front and rear axle weights, but non of those figures add together to correspond. some one else might come along and explain. edit....and they have done.
jollyrodger
6,282
26,426
Devon/Cornwall
'Obby
Since 1968'ish
I think you'll find
3850 kg is your gross weight
5550 kg is your gross including trailer
The others are axle weights
Though I stand to be corrected ;)
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
The two explanations are spot on and no they will not add up, the 3850 is a weight with everything and everyone in that you cannot legaly exceed, again fully loaded your rear axle must not exceed 2120Kg and similarly fully loaded your front axle may not exceed 1850 Kg the other figure is your maximum allowed weight with a trailer hooked up
JonVonandDog
JonVonandDog
18
8
Wellingborough
motorhome
I`m a newbie
Many thanks!!! Oh well, suppose that means a complete unload and some scales. Not so sure about Von and Dog tho. but then again something may have to be jettisoned. Thanks again.
DuxDeluxe
14,668
72,983
Planet Zog
A woosh bang van
since 2008
Yep - find your local weighbridge and get both axles plus the overall weight. It will be the second best tenner you ever spent...... and may save a ticket/fine/un scheduled unloading
1,192
1,871
West Midlands
Hymer
Sometimes best to get the van weighed as you would normally run it, then make adjustments. My local trading standards will weigh the van for free, they only charge if you want the printouts and certificates. You can use the loaded weight to get tyre pressures from your tyre manufacturer. As stated above, better to be safe.
43,371
49,742
a correction to Lanesides post.....
the two axle weights exceed the vehicles maximum weight to allow for uneven loading.
if one axle (front or rear) is loaded to the plated limit then the other axle can only be loaded to total the maximum vehicle weight.
ie: rear = 2120kg
front = 1730kg
or
front = 1850kg
rear = 2000kg
or any combination in between.
5,956
39,426
Uk
If you want to get your Motorhome weighed go to Whitworths just of the A45 , they do it for a good price, a few years ago it was ÂŁ8 for 2 weights ( total and rear)
