It seems like your system is a pressurised system as you say the pump runs OK but does it stop the you shut all the taps, may take a few seconds. If it runs and runs then you have a leak somewhere, start by purging the nearest tap to the pump and work progressively away until all are purged, ensure that the boiler drain is also closed and check both hot and cold are purged which involve a lot of gurgling. If it still does not purge then you have an air leak somewhere. If you have push fit joints or the type like mine which are German with Reich Unicquick connectors check that the small push clip built into the drain is still in place as this locks the pipe to the connector. A quck check is pull out the clip, and check the pipe is fully inserted then replace the clip. Also check hat the drain is not slightly dripping, I had one which was resulting in an air leak. The drain valve has to be replaced fully as they are not repairable but not expensiveBought van and system was shut down for winter,filled tank & switched pump on,pump working ok. Opened tap to purge any air ,but still no joy,no water to taps sink,shower or toilet. Help please. Ken
