Water pulsing problem at the filter (1 Viewer)
May 14, 2018
19
23
North Yorkshire
Coachbuilt low profile
Newbie
Just getting ready the season. I have been sanitising the water system. I am now getting a pulsing at the filter which doesn't seem to retain water, and the cold water feed pulsates. Any ideas? TIA.
Dec 6, 2011
11,622
25,526
South Wales
Coach built Adria
Ps: that filter bowl is after the pump so if the problem was post pump it would at least be filling the glass before emptying it again and causing the pulse.
Therefore to me the fault lies in the pump or the feed to the pump.
May 7, 2016
7,288
11,781
West Sussex
Carthago Compactline
Since 2003
I would start with checking the filter bowl and seal. A crack in the bowl is not unheard of after a winter lay up. The pressure on the filter side of the pump drops to draw water from the tank but if there is a leak it will draw in air rather than water. In your case the amount of air looks significant. I agree with Phill D that the leak will be between tank and pump but I thought the filter was in line before the pump to protect the diaphragm (but always open to be corrected and learn something new).
Wallace
May 14, 2018
19
23
North Yorkshire
Newbie
The filter is before the pump. The water feed pipe comes up from the floor from the tank, has a right angled elbow then onwards to the filter. I have checked the clear part of the filter bow, which I replaced last year, and there seems to be a distortion in the plastic (see pic). I changed the pump and filter last year after pump problems and if I'm honest, it was never really good. I will order up a replacement and take it from there. Thanks guys 👍
43,367
49,716
The filter is BEFORE the pump to prevent debris getting onto the valve seats and holding them open.
It'll be the filter bowl is cracked as usual or maybe the bowl rubber O ring has failed
RM_Marine
677
1,161
Poole, UK
Autotrail Apache 700
Since 2021
Wallace
I'll nip to the motorhome tomorrow and take the cap off mine and send you a picture as I've got to get something out of van anyway and its parked on the tennis courts at work anyway
Hopefully it's a faulty cap and nothing more serious
TheBig1
17,644
43,453
could also be faulty pressure switch and or non return valve not allowing the pump to build pressure and maintain it
Dec 2, 2019
4,120
9,246
South Lincolnshire
Rapido 7065+
Broken most bits now
Just needs time to pump through to 'solid" water - can take up to 2 weeks but usually just a couple of days
Wallace
May 14, 2018
19
23
North Yorkshire
Newbie
Try mounting it with the bowl underneath, looks like air in the bowl that won't clear.
It was originally mounted the other way up. I had previously turned it to bowl uppermost to see if it made a difference. Sadly it didn't.
May 13, 2014
119
217
Bury St. Edmunds
since 2009
Like mentioned position bowl to the bottom, clean mesh well as fine film of lime etc can slow flow, if not leaking should be ok.
If a shurflo pump did you adjust it when fitted.
Make sure you have a good supply of water in tank to help get the pump to prime.
If still no go, strip pump check for splits/damage/dirt, if all looks good clean and lubricate with a potable lube, refit and try again.
Forgot to say, check the filter bowl seal is good and lubricate it when refitting.
RM_Marine
677
1,161
Poole, UK
Since 2021
Sorry about the late pictures
Mine is sited the same way round as yours
Mine doesn't have that random lip in like yours
Apr 3, 2018
3,687
10,269
PVC
1995-2004 & 2017》
For info..
My filter used to be the other way round.. but it was a pain to remove glass lid and clean filter so I turned it so glass at top..
Since then mine does the same as yours....
Bubbles through the glass bowl....
HOWEVER water flows through taps as it should with to spurting or gurgling..
May 7, 2016
7,288
11,781
West Sussex
Since 2003
In general filter bowls are designed to hang down, so that trapped particles collect at the bottom away from the main flow. With these filters putting them upside down will not only let the particles fall the wrong way but will trap air in the upturned bowl, air which would normally be purged through the system and out of the taps.
