Water not working (2 Viewers)
tonyandcarol
525
35,587
Spilsby Lincolnshire
Niesman bischoff Fla
since 2005
Hi all
I drained down all the water this winter but today I party re filled it but the water pump is running but not getting water to taps or boiler. It is a Flair 8000i any tips please.
Apr 22, 2018
6,857
12,640
Herts.
Adria Coral lowline
As mentioned above. There is normally a filter, with plastic bowl directly before the pump. The bowls can split, so the pump then just sucks air in and not water. Worth a check.
Sep 3, 2012
7,651
26,327
Cheshire
C Class Elddis 175
8+ years
Hi Tony, different van but happened to us. I connected a hose to a tap opened the tap and gave it a good hard suck. A couple of times and it worked. Filled the pump or system and it just then filled up the pipework after that with the pump.
Jun 10, 2010
8,645
20,584
Shrewsbury (sometimes)
N&B Clou Liner MAN
Hi all
hi , are you sure you have closed all the drain taps? if you have Alde you probably have a tap each for the hot and cold circuit as well as the tank one. assuming you have the shurflow pump?
any ideas on this one funflair
tonyandcarol
tonyandcarol
525
35,587
since 2005
Hi yes all drain taps closed 3 in total next to each other plus the waste tank drain next to them. Not having a good day no gas now getting to van from gasit twin bottle system.
Aug 8, 2019
396
567
Chichester
Autosleeper Broadway
Since 2019
I had the same with an airlock last year, in the end I drained it completely then with all the taps open I filled it really, really slowly et voila!
Jan 19, 2014
9,444
24,967
Derbyshire
Elddis Accordo 105
since 2014
Unplug the pump outlet pipe briefly, and have a towel ready 😎👍
Dec 31, 2010
2,667
5,908
Sunny South Shields
Frankia Platin i7900
I normally take the shower head off Tony crack the taps open slightly then suck the water through the shower hose probably just a airlock
tonyandcarol
tonyandcarol
525
35,587
since 2005
Thanks Jim. I will try that.
tonyandcarol
tonyandcarol
525
35,587
since 2005
Thanks Dave I have only put a small amount in the system so will try again with a full fill. Not having a very good day not getting any gas through now I have tried that I thought the 2 bottles were OK but a will check it could be a faulty regulator.
Sep 3, 2012
7,651
26,327
Cheshire
C Class Elddis 175
8+ years
Have you a crash button on your regulator that has opened?
Dec 31, 2010
2,667
5,908
Sunny South Shields
The joys of motorhoming 😤
Jun 10, 2010
8,645
20,584
N&B Clou Liner MAN
are you level?
19,600
31,448
I can't say I ever had a problem and I don't it will be Flair specific anyway, saying that though I very rarely drained down properly, could be one of the little valves stuck and a suck/blow might well get it going I would think.
Apr 3, 2018
3,778
10,555
1995-2004 & 2017》
Hi Jim all sorted now. I unscrewed the little glass top off the water filter and that got rid of the air it working OK now. Thanks for the tips.
tonyandcarol Sorry.. late to this thread .. and I know you are now sorted, but just a thought for next time.
You said you unscrewed glass bowl on TOP of the filter.... That may possibly be the problem, that glass bowl should be at BOTTOM of filter pointing down. Could it be trapping the air by being the wrong way round?
Mar 27, 2017
22
13
Nottingham, England
VW Devon Sundowner
Hi all
Hi all
After my tank has being empty I find that I have to fill the tank fully before the pump starts working, think it's a priming thing (VW)
