Water Level Probe (1 Viewer)
Sep 10, 2017
427
964
I've managed to break the fresh water tank probe in our 18 plate Campscout Revolution, does anyone know what make they are or where to get one?
PP Bear
7,871
29,130
Kent, UK
Auto Trail Dakota SE
I don't like things not working and it's not overly accurate but easier than looking in the tank.
I'm with you on this, if it's fitted, it needs to work!!
Mine only shows intervals of 25%, 50% etc, but at least I know when it reads 25% and we've all showered etc, it's time to refill again.
Drives me nuts when things don't work as they should. šŸ˜‹šŸ¤“
Apr 22, 2018
6,843
12,619
Herts.
Adria Coral lowline
How, i what way, have you broken it?
Can it be fixed?
427
964
Can it be fixed?
I was trying to remove it and slipped breaking the wires flush with the top.
I also can't get it off as it is just spinning and not unscrewing, I think I will have to cut the plastic nut off to remove it.
Aug 6, 2013
11,962
16,582
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
It may have a nut inside the tank that you need to hold whilst the sender is unscrewed.
PP Bear
7,871
29,130
Kent, UK
Might be the only way....
Sep 23, 2013
2,591
8,905
Lincs
Globecar Campscout
Doesn't help, but why bother... They are never accurate or dependable.
Same goes for the grey tank probes.
You're right, it doesn't help.
The fresh water level display in my Globecar has been accurate enough for the purpose it was designed for during the seven years we have owned it. If it stopped working, I'd want it fixed too. Due to its position, looking in the tank isn't a practical alternative.
