Wanted - Bedford CF250 reverse light switch (1 Viewer)
GJH
29,450
38,827
None, now sold
2006 to 2022
Number one son has discovered that his reversing lights don't work because the switch is bust.
He has found a price for a new one (BEDFORD CF VAUXHALL 4 SPEED GEARBOX new reverse light switch + plate) of £51 plus delivery at an on-line site but I wondered if anyone knew where we might be able to get one cheaper
Entering the vehicle registration number at another parts web site identifies the base vehicle as a Bedford BLITZ (CF97) 2.3, 79 hp, 2278 cc.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
it will probably be the same as fitted to the early rear wheel drive vauxhall cars so if you can find a breakers yard locally you may be able to source one there for about £10.00
alternatively if you can get it out of the gearbox it may just be that the plunger is stuck.
also early reversing switches had the terminals fixed to a plastic disc that was held in place by crimping the end of the switch.
or it could be a duff wire.
con-tiki
457
187
Leeds, West Yorkshire
A class Hymer
since 2009
Try this... Link Removed is a breaker, but can be a bit pricey. The bedford CF forum might be able to help.
Shirl
G
GJH
29,450
38,827
None, now sold
2006 to 2022
Thanks, I'll pass that on.
Cant help with the light, Graham, but how's he getting on with fettling it generally?
Pretty well John, thanks. Between him and his mates they can cover most things.
Shirl
Thanks Shirl - he's the bloke who has one for 51 quid ::bigsmile:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Rather than pay 51 pounds you could buy an illuminated swich and wire them to that (yes I know you would have to remember to switch it off) but its a cheaper option
scotjimland
2,479
10,845
A Woosh bang
As far as I know the reversing light is not a testable item in the MOT ..
.. One way around this is to fit another switch but it must have an illuminated warning light to tell you they are on (same as a rear fog lamp)
G
GJH
29,450
38,827
None, now sold
2006 to 2022
Thanks fellas. I'm pretty sure that's right. It certainly used to be because I fitted reversing lights, with a manually operated illuminated switch, to the first car we had in 1980/81.
G
GJH
29,450
38,827
None, now sold
2006 to 2022
Is this one any good
Link Removed
Thanks but unfortunately not. Apparently the plunger(?) was longer on the earlier CF models Link Removed.
That one on eBay (and one or two others) is for a CF2 version a couple of years younger :Sad:
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
graham! it's posible that i have a few part's(all new)to fit this bedford.IE wheel brake cylinders,brake shoe's,posibly a water pump,disc pads if fitted?air filter, oil filter,,disy cap,points,service parts mainly:thumb:i have 1000's of part's for older vehicle's,all new in box's(old stock):thumb:
G
GJH
29,450
38,827
None, now sold
2006 to 2022
Thanks Chris. I know he bought points, condenser, dizzy cap &c plus timing belt kit and other parts for full service. If you have a reverse light switch he would definitely be interested ::bigsmile:
