Vodaphone coverage for TV (1 Viewer)
Sucoz
176
206
Isle of Wight
‘A’ Class
since 2011
We have a cello traveller TV and currently stream it on my Vodafone sim. However, whilst I have read on here that peop!e get good coverage with Vodafone we are finding the signal not strong enough throughout many places in France.
We don't watch many films I just want to be able to get the odd iplayer programme for rainy days.
my question is would a mi fi solve the problem or do I need something else?
Addie
Trader - Motorhome Wifi
Oct 15, 2011
553
834
York
Don't forget that with Vodafone you can manually roam onto any network when in Europe - so perform a manual network selection on your device (presume a phone?) and see if another network provides better coverage. This may take a little bit of time to search and connect, test and perhaps repeat as the process is slow, but usually, an alternative provider will have a faster connection.
There is no real benefit in just having just a MiFi device over a (decent) mobile phone handset in terms of cellular performance unless you intend to connect that MiFi to an external antenna at some point which is where the performance difference can be significant. I would say I rarely hear of our customers having issues streaming TV in France and we're usually the first to know at 7:30 when a certain soap is on!
I would say I don't know much about the Cello TV, but you tend to find that 'Smart TV's tend to not hold the same sort of video buffer as a tablet or even a Firestick. So do try and stream on another device and/or make sure the quality is turned down as low as possible on the stream you are watching.
DBK
18,041
48,176
Plympton, Devon
PVC, Murvi Morocco
Assuming you are using a phone try putting it near a window or under a rooflight.
Try changing provider. In France Vodafone should work with SFR and Orange. One usually works better than the other but it isn't the same one each time. :)
A mifi with an external aerial will work almost anywhere in my experience but try a mifi on its own first. Make sure to buy one with two antenna connections if you can as this leaves open the option of adding a good antenna later. Something like the Huawei 5577.
Nov 4, 2011
5,951
39,257
Uk
I’m just trying Vodafone pay as you go at the moment, not for streaming, just normal data stuff and I haven’t got 4G yet and that’s around St.Noets area so I may not stay with them.
Sucoz
Sucoz
176
206
Isle of Wight
‘A’ Class
since 2011
Thanks for the advice everyone - it usually chooses SFR and I had assumed that it would automatically choose the best option, so will bear that in mind. I don't understand Addie how I turn the 'quality as low as possible on what I'm streaming' i looked on the internet but couldn't really follow it. We have found that sometimes the iPad work's better than the TV.
Anyway tonight I turned all other devices off and it was fine, so will continue experimenting.
Dec 29, 2012
505
30,697
Cheltenham
Rapido 7066df
Since 2014
I think SFR is Vodaphone's preferred provider in France and automatically connects to them. I found it all but impossible to stream tv on the fire stick but after manually selecting Orange F it worked perfectly for 10 weeks
gerry mcg
1,650
2,573
Glasgow, Scotland
Globecar 600L Revn
since 2016
I guess Addie is suggesting you try streaming at Standard Definition (SD) rather than high definition (HD) as the lower quality image requires less bandwidth
Sucoz
Sucoz
176
206
Isle of Wight
‘A’ Class
since 2011
Thanks Gerry mcg, haven't watched any tv lately, too hot in France, but will bear it in mind.
