Victron Venus OS and a Rasberry (3 Viewers)
Oct 14, 2007
4,009
6,284
Rochester
Auto-Trail Mohawk
16 fun filled years
Sep 17, 2017
5,525
10,339
Birmingham, UK
A-Class
I managed to get it to communicate with an ESP board without many issues (running ESPHome to Home Assistant).
Oct 14, 2007
4,009
6,284
Rochester
Auto-Trail Mohawk
16 fun filled years
Not sure I can be of much help, I didn't deliberately buy the HX version, I just plugged the cables in and booted up the RPI. Looking at the MPPT the only setting I can see that would effect matters is the RX TX settings but why would they have been changed from their defaults anyways. I'm still on an earlier version of Venus OS 2.72. Do the devices appear in the device list on the remote console, is VRM online portal two-way communication enabled?. I assume Venus OS will log events so you should be able to tell whether the PL2302' are active- don't ask me how but presumably accessible via ssh. The PL2302 do require some power but I'm using 3 USBs on an RPi 3+ with a 2amp feed
The device was showing as off thats why I thought it was a comms prob. 2 way comms is enabled. I didn't have time to hard wire everything in and plugged into a cigarette power adapter and that may be an issue also. Will be doing a hard wire later and try the other things. If all fails I will try the different USB adapter cable.
Thanks for yor suggestions.
Dec 2, 2019
3,617
7,814
Amersham
van conversion
Since 2019
I know you said you got the wires the right way round on the plug, I looked at various sources on the net, and lucky I did. First time I had the wires on the wrong pins. It’s worth eliminating this before you change the serial converter. Once plugged into the RPi, any device that’s on, you should see it on local.
Aug 18, 2011
12,162
18,033
derbys
AUTOSLEEPER SYMBOL
Not got a clue what the above posts relate to are they written in code?😆😆😆BUSBY.
Dec 2, 2019
3,617
7,814
Amersham
van conversion
Since 2019
He knows what I meant. Two on tour posted a photo with the plug, I’m on about those wires going into the plug. When you plug it into mppt, I realised it’s the other way facing and my pins was in wrong order. If they are in the wrong order, the raspbery pi will not see the device. If they right, it will show within seconds on local network, and vrm.
Oct 14, 2007
4,009
6,284
Rochester
Auto-Trail Mohawk
16 fun filled years
It's showing on local as Rpi3 with IP Addy and Vrm ID I think pinout is ok see photo
Oct 14, 2007
4,009
6,284
Rochester
Auto-Trail Mohawk
16 fun filled years
I'm seeing this VRM device list
Sep 16, 2013
2,220
7,993
Horncastle, UK
Van Conversion
Since 2006
Slightly off topic (as using a Cerbo GX), but I get to wire this lot up next week:
Ignore the EHU charger, but it's likely there will be another two MPPT 100/30's (change in solar config). Think this is the most Victron I've ever fitted to a van. Should be fun :giggle:
Jul 6, 2009
1,826
2,257
What current draw would you expect from all this monitoring capability?
S
May 19, 2020
205
248
Knaus Sun Ti 650 MEG
Since 2020
As far as I’m aware the Linux kernel should have drivers inbuilt for both the HX and TA versions
Oct 14, 2007
4,009
6,284
Rochester
Auto-Trail Mohawk
16 fun filled years
Just got back from trying the PL2303TA lead and all good:xThumb:, so either the PL2303HX chip is not supported or my one was duff.
Anyway all good now and many thanks for all the help.
Apr 27, 2016
6,895
8,034
Manchester
A class Hymer
Since the 80s
The descriptions I've seen are a bit vague, but the TA and HX are both USB-to-Serial adapters. USB = Universal Serial Bus, as I'm sure you already know. I think the TA is a general serial converter, maybe 5V levels, and the HX is for RS232, which has 12V Receive and Transmit lines.
Sep 17, 2017
5,525
10,339
Birmingham, UK
A-Class
If an ESP board can connect to it with boggo serial ports, it shouldn't be a major issue.
Two on Tour
10,406
51,601
Elddis Autoquest 175
Since 2010
Yes, well spotted, the 1st one that didn't work was the PL2303 TA due to either not being supported by the Venus OS or duff, the second one the TA2303 HX worked. Sorry for the confusion.
I was not trying to be cocky or trip you up, I was just concerned that if somebody was reading through the thread for information, that it might have caused some confusion.
Dec 2, 2019
3,617
7,814
Amersham
van conversion
Since 2019
Are you life on VRM now?
